Author Topic: can you use marker lights as signals  (Read 779 times)
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
« on: April 07, 2008, 08:16:59 AM »
Looking to replace signals found some cool marker lights at local auto parts store...only one wire...wasnt sure if they would work as turn signals or not...
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline mystic_1
  • 1970 CB750K
Re: can you use marker lights as signals
« Reply #1 on: April 07, 2008, 09:03:07 AM »
If they have only 1 wire, you could use them as either marker lights, or turn signals, but not both at the same time, unless you bought an aftermarket module that provides this functionality.
mystic_1
- John Augustus Shedd
  • stupid gloripope
« Reply #2 on: April 07, 2008, 11:21:48 AM »
would i need a ground wire to or just hook the one wire to turn signal wire.
Offline Gordon
  • 750K1, 550K2
« Reply #3 on: April 07, 2008, 11:28:14 AM »
Single wire lights ground through the point of attachment.  As long as the part that you bolt the signal to is grounded, it will work.
Offline 333
  • Time for change
« Reply #4 on: April 07, 2008, 11:28:49 AM »
And won't be as bright, unless a higher wattage bulb is used.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
