Author Topic: 77 550k, pilot jet screws, how many turns out?  (Read 843 times)
Offline narcoticrex
« on: April 07, 2008, 12:26:18 PM »
My Haynes manual says 1 and a half.  When I just checked them, they were out 2 and a half, or more.
i guess this means i should buy a vacuum gauge, huh?
"i love the smell of cooked beaver in the morning...it smells like....victory."
Offline moham
  • .fnord.
Re: 77 550k, pilot jet screws, how many turns out?
« Reply #1 on: April 07, 2008, 01:07:25 PM »
78 750K-The Ocho
74 550-The Cherry Picker
70 750K0 motor-Dick in a Box
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: April 07, 2008, 01:23:32 PM »
The factory settings for the idle mix screws are just a baseline starting point.  Many bikes will run fine at this setting, but they should be set for your particular situation.
As for the vacuum gauge, the idle mix screws don't affect overall vacuum.  You'll need one of those to synchronize the carbs, but that's a different procedure from setting the idle mix.
Offline moham
  • .fnord.
« Reply #3 on: April 07, 2008, 04:23:33 PM »
there's a bunch more stuff here (a lot specific to 550's from the looks of it...)
http://forums.sohc4.net/index.php?topic=5410.0
good luck.
78 750K-The Ocho
« Reply #4 on: April 07, 2008, 06:34:30 PM »
The Honda spec booklet also says 1 1/2 turns out from LIGHTLY seated.  Only applies if you have stock exhaust and air filter, though.  Otherwise, it's just a starting point.  It's adjusted with a sensitive tachometer, not a vacuum guage.
