Author Topic: Removing rear springs  (Read 910 times)
kevio
« on: April 07, 2008, 06:43:07 PM »
Do I need to use a special tool to compress the rear springs before removing them?  Or can I just remove the rear wheel and then take them off?  The shop manual doesn't make it very clear.  They simply say to remove them.  I don't want a spring in my face or foot.
Thanks,
Kev
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
Re: Removing rear springs
« Reply #1 on: April 07, 2008, 06:51:28 PM »
The shock assembly can be removed as a unit(s) without the spring compressor. A bolt at the bottom and a nut at the top and they come of. To remove the springs from the shock absorber.... that you might need a spring compressor for, but you have to take the shock assemblies off the bike first.
 Matt.
Gallery at:
kevio
« Reply #2 on: April 07, 2008, 08:42:12 PM »
LOL, sorry. I should have said shocks instead of springs. But it sounds like I can just pull them off without getting shot in the face.  ;D
Thanks,
Kev
Offline lordmoonpie
    • Moonpie
« Reply #3 on: April 08, 2008, 01:42:07 AM »
If you fancy living dangerously and are now upset at losing the thrill of dismantling your rear shocks - go to the front and undo that top nut on the fork leg.....stand well back tho'  ;D
1994 Ducati 888 SP5
1951 Ducati 50cc Cucciolo
1981 Yamaha XV750 SE
