Oil line size from Earls is AN -10 or ID 9/16". I used Perform-o-flex for my hoses, earls part no. 400100. All you need do is get lengths of this plus the nice end caps to tidy it up and just cut the old swaging off the original fittings to re-use them. Works a treat plus that allows you to polish up the alloy on the original fittings.
If you use a Bartel/Mead Speed type oil tank and want standard lines to the engine you will need:
20.4cm and 23.4cm lengths of 400100 and I used chrome econofit hose tidies at each end - so you'll need four off 900310 13/16" fittings.
If you have an oil cooler and want to plumb that in, you'll need the standard input line from the oil tank to the cases as above (can't recall which length that was right now!) plus additional lines of length 71.4 cm and 107.5cm and a couple more hose tidies...
If you're making your own oil tank I guess you'll just have to measure the lot yourself
![Cheesy :D](http://forums.sohc4.net/Smileys/default/cheesy.gif)
