Author Topic: this maybe a dumb question but  (Read 644 times)
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
« on: April 08, 2008, 12:16:34 PM »
if you put the spark plug wires on in the wrong order would it still run...just not as good or would this cause it to not run at all.
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline Bodi
Re: this maybe a dumb question but
« Reply #1 on: April 08, 2008, 12:37:22 PM »
You can swap 1 & 4 or 2 & 3 at will, each pair goes to the same coil. Don't swap 1 & 2 or 3 & 4 though, you'll be running on only two  cylinders and one of the others may backfire through its carb (this can burst and/or light the air filter on fire).
