Author Topic: HM341's baffles  (Read 741 times)
Offline greenjeans
  • 1972 CB750K2
HM341's baffles
« on: April 08, 2008, 02:11:19 PM »
Just noticed that the PO has broken the bolts  (all 4!) that hold the baffles in.
1.  Should these just slide out if I can drill the remaining bolt out a bit ?
2.  There are supposed to be a tiny drail hole close to where the header pipe and muffler are welded correct ?
I'm assuming the baffles can be re-used / painted etc....
Offline Jonesy
  • Shop Rat
Re: HM341's baffles
« Reply #1 on: April 08, 2008, 02:39:02 PM »
1) Yes, they should come out with the remaining stub of broken bolt gone. There is a little slip-fit holder inside the muffler that might try to grab the backside of the diffuser (soot, crud buildup), but it should come out.
2) Yes, there should be a tiny drain hole for each pipe.
If you can get the broken bolts out, you can re-paint the diffusers if you want.
