Author Topic: Increased ethanol content of gas causes noticeable hardening of rubberized parts  (Read 1394 times)
Offline azuredesign
  • Knupping pin
Maybe I'm losing it, and maybe not. I replaced my fuel lines with high quality reinforced material last fall. Today was a good day for us here in central New England as the temp actually wiggled up above 50 slightly. I skipped out on work at 2, and got my cb ready for spring start. I was surprised to find how hardened the lines had become, even though they had been drained, and in a heated garage all winter. At the end of last season, Scott (S-Dog) had noted that my carb intake boots were hard as a rock, which they weren't when I started the bike up after it had been apart for 2 years.
How long are lines and boots going to last now that there's all this alcohol in our fuel? What other parts should I watch out for? Kind of a drag!.
On the bright side, my 35 year old bike started right up. Unfortunately riding it a bit reminded me of all the things I need to do that I'd forgotten about. :o ;D
Not sure what kind of cheap fuel lines you are using Ben  ;) but having rebuilt my K4 in a morning this last Sunday when temps were a cool 40s I can share this with you....my stock fuel lines were not hard and I had the easiest time EVER getting my carbs on the engine rubber boots  - I really couldnt believe how easy it was...until I tried the airbox and that was even easier!!! Its had to have taken oh all of 2 mins! Yes literally!
New rubber last year really paid off  ;D
Now...if I could just say the same about my fork gaitors...riding in 30F temps has left them in tatters  :-\
see you soon,
cheers
Andy
Offline azuredesign
  • Knupping pin
HUH? Well then I am losing it!
 Ben
 Sure its not the acetone you've been sipping. ;) ;D
Mike R got me a set of boots a couple of years ago and they are still pulsing at idle so I know they are still quite supple. I use a urethane fuel line so that is not an issue with ethanol for me. The carb rubbers may be a different story, I am not sure how wet with fuel they get and if they will be hardened. I think the heat from the motor would be more degrading.
Ethanol (10%) has been in most pumps I have seen for a LONG time.
