Author Topic: CB 500 Electrical Q?  (Read 843 times)
Offline winnipeg550guy
« on: April 08, 2008, 04:09:59 PM »
I've done some modifications to my mostly CB500 and It's been so long getting it together a few things have slipped my mind in the lighting area.
 Main thing is the tailight, it isn't stock but I've used the wires and socket,  I'm aware it's dual filament but it doesn't Illuminate during normal operation, but lights up when I apply the brakes, I can't recall if this is normal just seems like it should be on as a running light as well.
74\' 550k., 1965 Suzuki K15, 1978 BMW R80/7
Re: CB 500 Electrical Q?
« Reply #1 on: April 08, 2008, 05:06:49 PM »
A stock cb500 had a General light switch.  The tail running light was on when the switch was on as was the headlight.
Offline OldSchool_IsCool
  • Really feeling like an
« Reply #2 on: April 08, 2008, 05:08:26 PM »
yes, it should have tail light and brake light functions.  Are both filaments good?  Here is a wiring diagram, stock of course.
http://oldmanhonda.com/MC/wiring500.html
If you take care of it.
What do you have to do?
Will you show me all of them?
Sure.
Is it hard?
Offline hapsh
    • Listen to the latest tracks from JazzCancer
« Reply #3 on: April 09, 2008, 09:46:20 AM »
hook the separate wires up to your battery and find out if both filaments are working.  One should be dim and the other bright.  If you use the wrong wire for ground it will only have one brightness for both wires.  Once you know what wire is for what indicator you can wire it all up without much problem.
'71 CB500/550, '72 CB450, '79 RD400 Daytona, '90 FZR600R
« Reply #4 on: April 09, 2008, 11:26:28 AM »
 Thanks for the suggestions I got all the wiring nicely sorted out and it turned out to be a ground problem
