Author Topic: LED question for guy with no idea for electronics  (Read 1726 times)
Offline stay youth
« on: April 08, 2008, 07:11:07 PM »
hello so I went to radioshack today to try and get some new LED's for my dash display and I got these:
http://www.radioshack.com/product/index.jsp?productId=2062374&cp
Figuring these looked cool and would work I snipped the orange and green wire coming from my left side turn single indicator. Well i did not work. The new LED has just two black wires coming from it. Can anyone help me along?
I guess I should have asked before I bought them, but I get excited and forget to think sometimes
1976 cb400f
Offline Steve F
Re: LED question for guy with no idea for electronics
« Reply #1 on: April 08, 2008, 07:12:56 PM »
The lights you show in you link are NEON, and require 50 to 130 volts to work.  You need something to operate on 12V DC.
Offline Steve F
« Reply #2 on: April 08, 2008, 07:17:38 PM »
Also, you need to pay attention to polarity when using LED's.  Everything except the NEUTRAL and OIL PRESSURE lights are normally grounded on the (-) minus side and power to turn on the light is switched (+)positive.
The NEUTRAL and OIL lights are supplied with power all the while the key is on to the LED's (+)positive side, and are then grounded through the neutral switch or the oil pressure switch.
Offline stay youth
« Reply #3 on: April 08, 2008, 07:59:29 PM »
Thanks so much for the feedback, I assumed the neon was LED haha Oh well they weren't expensive. I'll try again
thanks
1976 cb400f
Offline bistromath
« Reply #4 on: April 09, 2008, 01:48:51 AM »
Yeah you're going to need some high-intensity T1-3/4 size LEDs if you want to be able to see them, especially during the day. And if you do end up with LEDs that aren't packaged as modules designed for 12V use, you're going to have to put a resistor in line with them. Otherwise, you're going to let the magic smoke out the first time you turn the ignition on! Start with 470 ohms.
'75 CB550F
Offline Steve F
« Reply #5 on: April 09, 2008, 06:38:18 AM »
Forget Radioshack. Go to any heavy truck shop (Freightliner, International, Mack, Volvo, Kenworth, Western Star, Sterling, you get the idea) that carries Trucklite and get them to order you a set of these http://www.truck-lite.com/webapp/wcs/stores/servlet/ProductDisplay?catalogId=10001&storeId=10001&productId=57964&langId=-1 I have seen them and they are incredible! They are designed to be used as dash indicators. Even in full daylight you will see them.
Dang. those things are huge!  Do they have anything a bit smaller?
Offline Jinxracing
  • It's hot shit, not
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #6 on: April 09, 2008, 09:14:38 AM »
Those truck LEDs are cool...might lend the bike a '70s "Speed Buggy" kinda look.  ;D
Here's a site that tells how to calculate LED resistor values, just in case you decide to go that route:
http://www.theledlight.com/ledcircuits.html
–Captain Horatio Hornblower
www.thehairynickel.com
Offline goon 1492
  • Sucka Repellant
« Reply #7 on: April 09, 2008, 09:24:50 AM »
adavance auto, auto zone, or oreillys has a ton of small leds and even brake light leds but you might still have to go to radio shack for resistors to go with the small leds.
« Reply #8 on: April 09, 2008, 10:01:45 AM »
I use the body mounts from www.radlites.com and they are plenty bright in daylight.
Offline stay youth
« Reply #9 on: April 09, 2008, 10:51:54 AM »
thank you all so much for the replies. I currently have drop in LED lamps I got from
superbrightLEDs.com
I put them in and they worked with no problems. I want to use these
http://www.radioshack.com/product/index.jsp?productId=2062570&cp=2032058.2032233.2032297&parentPage=family
Will I still need a resistor to account for the low energy draw?
thanks again for helping
1976 cb400f
Offline Jinxracing
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #10 on: April 09, 2008, 11:00:53 AM »
superbrightLEDs.com
That one's already got a resisitor wired in...it should be plug-and-go. You might want to hook one up to a 12V battery while you're at Radio Shack to test how bright it is first though.  ;)
Offline stay youth
« Reply #11 on: April 09, 2008, 11:35:40 AM »
Ok great thanks so much
1976 cb400f
Offline stay youth
« Reply #12 on: April 09, 2008, 06:44:16 PM »
woohoo I love this forum. So I got the correct LED and it hooked up with no issues. Now I gotta figure out my blinkers aren't blinking.
thanks
1976 cb400f
Offline 333
  • Time for change
« Reply #13 on: April 09, 2008, 08:09:34 PM »
It's the flasher unit.  Superbrightled can help.
http://www.superbrightleds.com/carbulb-notes.htm
Replace the flasher unit.  If you go the load resistor route, you won't see any current savings.
« Last Edit: April 09, 2008, 08:11:37 PM by 333 »
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline stay youth
« Reply #14 on: April 09, 2008, 08:52:49 PM »
I thought I needed to replace the flasher unit if the blinkers were LED's? I  have these on my bike
http://www.cyclegear.com/spgm.cfm?L1=2&L2=53&L3=&L4=&item=MRX_OI1&tier2=14
1976 cb400f
