Author Topic: major problems????  (Read 1975 times)
cwalsh540
major problems????
« on: August 13, 2005, 01:04:07 PM »
alright here we go-
-1973 cb350 four
-went from stock to-
   -dyna s ingnition
   -accel non cdi type coils
   -new plugs and wires
   -4 to 1 exhaust
   -rebuilt carbs
   -form 75 to 100 main jets
   -single air filters
now, all electrics work, timing is dead on(checked staticly), engine cranks fine, but not starting and backfires. could it be the carb adjustments? it cranks for a while and then BOOM!
PLEASE HELP. VERY FRUSTRATED!
thanks
chris
mk0094@hotmail.com
Re: major problems????
« Reply #1 on: August 13, 2005, 01:36:00 PM »
if it is backfiring and not running, the cam shaft could be off 180 degrees, allowing it to fire when the intake is open. i had that problem a while back. make sure the camshaft is alligned properly.
Offline kghost
« Reply #2 on: August 13, 2005, 01:42:12 PM »
Well maybe not the cam since you may not have had the head off.
But what about plug wires? You got the leads to the coils hooked up right? if not and you're backwards you'll get the condition you are describing.
Stranger in a strange land
cwalsh540
« Reply #3 on: August 13, 2005, 04:46:03 PM »
thanks guys....but you were both kinda right. so i put on my old coils and the same thing, checked the timing 100 more times then just thinking thing through i realized that some IDIOT(me) had the wires swaped at the coil wires into the harness.  sooo stupid it could have been running hours ago....i guess if you cant laugh at yourself, who can you laugh at
Offline jbailey
« Reply #4 on: August 13, 2005, 05:15:16 PM »
Once you get it running, do yourself a favor and set the timing with a timing light.  I set mine staticly and find that it is usually off several degrees.  Since there are no degree marks, I can't tell exactly how much.  It doesn't make enough difference to really tell by riding, but it is usually off retarded.
1975 Honda CB550K
2005 Kawasaki ZG1000 Concours
Offline kghost
« Reply #5 on: August 13, 2005, 09:19:44 PM »
Do I win a prize?  ;D
Actually I'll just be content if no one asks how I know about swapping those leads.  ::)
Offline dusterdude
« Reply #6 on: August 15, 2005, 07:19:58 AM »
kghost,we cant let you be content now can we.so cmon and tell us how you know.
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
Offline kghost
« Reply #7 on: August 15, 2005, 08:15:40 AM »
My only reply would be this........
You can also assemble the advance mechanism 180 degrees off too.......
 ;D
Makes it really really hard to set the points. :D
77F2cb
« Reply #8 on: August 15, 2005, 09:43:28 AM »
On the 750, Dyna instructs you to time it at the "right hand" advance mark.  I do this "statically" by holding the timing cam (round magnet) clockwise in the fully advanced position, until it's right.  It can be a little hit and miss, rotate the plate, check again.........checked while holding in full advance, and the light comes on at the right hand advance mark.
Offline Tim2005
« Reply #9 on: August 15, 2005, 02:29:51 PM »
And now it's running, what's it go like, especially at full throttle? I'm just thinking that 100 main jets are pretty huge, I'm more used to 400Fs and on them I'd be looking at something around 85s with a similiar pods/pipe set-up.
