Author Topic: How loose is your rear sprocket??  (Read 1377 times)
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« on: April 09, 2008, 03:24:34 PM »
The rear sprocket on my lil' 350F is a little loose on the hub. It seems that the sprockets (studs or dowels?) are loose inside the rubber bushings in the hub.
It's not very loose, maybe 2-3mm or play at the teeth side to side. I drove it before I took it apart for the resto and it seemed fine.
My question, is there always a little play here, do your sprockets wiggle a little or are my bushings worn out.
 Cheers, Matt.
« Last Edit: April 10, 2008, 09:31:35 AM by mattcb350f »
Gallery at:
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: How loose is your sprocket??
« Reply #1 on: April 09, 2008, 03:37:46 PM »
mine wiggle.
Offline hoodellyhoo
  • CB350F
« Reply #2 on: April 09, 2008, 05:45:04 PM »
same here
« Reply #3 on: April 09, 2008, 05:51:00 PM »
Mine wiggle when I run. ;D
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #4 on: April 09, 2008, 06:32:51 PM »
Good enough for me, together she goes..  ;D
Thanks, Matt.
Gallery at:
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
« Reply #5 on: April 09, 2008, 06:40:53 PM »
"The rear sprocket" ...............Wait, I recant my above post........ "really" .........I thought you said front sprocket :o
My rear is not loose...........and I mean that in any way you wish to describe it ::)
jokes will not be taken lightly.
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #6 on: April 09, 2008, 06:50:11 PM »
Nope, the rear.... and I've seen a few other bikes that are loose. Just wondering what's worn or is a little looseness alright
 Matt.
Gallery at:
Offline kayaker43
« Reply #7 on: April 09, 2008, 07:46:32 PM »
Big squishy rubber things inside the hub make up what they call the "cush" drive. It minimizes shock loading on the gearbox. When new they are pretty snug but most will loosen up.
Slop is not ideal, but is totally harmless.
Offline 333
  • Time for change
« Reply #8 on: April 09, 2008, 07:56:24 PM »
At 25K, mine are pretty snug.  While the idea is to "cush"ion the acceleration, there shouldn't be any play when moved by hand.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline tsflstb
« Reply #9 on: April 09, 2008, 09:28:20 PM »
I don't know what the service limit is on those cush drive rubbers, but if you choose to remove them...good luck is all I can say.  I have blocked out that week of my life from memory.
http://forums.sohc4.net/index.php?topic=27968.0
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #10 on: April 10, 2008, 09:32:43 AM »
Good lord man!!  :o
Mine are tight enough  ::)
 Matt.
Gallery at:
