Author Topic: id problems  (Read 924 times)
willhwhitt
id problems
« on: April 09, 2008, 07:04:39 PM »
   How do you find out which model cb750 ('76) you have? i.e.k1,f so forth.
76 cb550
Re: id problems
« Reply #1 on: April 09, 2008, 07:24:27 PM »
check the first part of your vin
If it starts with F it's an f if not it's a K
(I think)
willhwhitt
Re: id problems
« Reply #2 on: April 09, 2008, 07:36:48 PM »
 It starts cb750.
76 cb550
Re: id problems
« Reply #3 on: April 09, 2008, 07:39:26 PM »
I should really just be quiet when I don't know exactly what I'm talking about...
Offline 333
  • Time for change
Re: id problems
« Reply #4 on: April 09, 2008, 07:45:57 PM »
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
Re: id problems
« Reply #5 on: April 09, 2008, 07:47:46 PM »
Re: id problems
« Reply #6 on: April 09, 2008, 07:49:54 PM »
If you look at the outer edge of the head, and it is 4 round bars, it is 72 or earlier, then if it has a seperate cable to each carb it is 69 or 70.
If it has 3  sorta  oval bars, then it is 73 or newer.
Then if it has a shift pattern cast into the transmission cover it is 75 or newer.
77 & 78 K have studs on the exhaust ports, and will have an output shaft ( for front sprocket) with no groove in it for the reatainer.. and should have a wider sprocket (630 chain if stock)
If you cant narrow it too 2 years you are doing something wrong..
willhwhitt
Re: id problems
« Reply #7 on: April 09, 2008, 07:54:41 PM »
