Author Topic: Do aftermarket kickstands exist?  (Read 1938 times)
Mattydiah
« on: April 10, 2008, 12:04:11 PM »
One of the genius previous owners of my 77 750K decided it would be a good idea to not only take off the kickstand, but grind off the mounting tab from the frame.
So now I have a centerstand and some boogery welds and a little chunk of metal where the kickstand mounting tab used to be.
Needless to say this is very obnoxious.  Is there any sort of aftermarket kickstand that can mount to the frame or anything like that?
Offline mystic_1
  • 1970 CB750K
Re: Do aftermarket kickstands exist?
« Reply #1 on: April 10, 2008, 12:44:51 PM »
Sure, look at Harley kickstands, so long as you're willing to weld it on.
mystic_1
- John Augustus Shedd
Offline bunghole
« Reply #2 on: April 10, 2008, 02:36:01 PM »
Use this as an excuse to go pick up a shiny new mig welder :)
Welding is fun!
'05 HD FLSTCI (Heritage)
'06 Suzuki DRZ400S
'08 Honda VFR800
'77 Honda CB750K
fuzzybutt
« Reply #3 on: April 10, 2008, 05:01:45 PM »
i wouldnt think just clamping it on would be strong enough
« Reply #4 on: April 10, 2008, 10:16:17 PM »
I cut mine off too.. ;D
Offline heffay
« Reply #5 on: April 10, 2008, 10:42:06 PM »
why would you cut the sidestand and not the centerstand?  ???
« Reply #6 on: April 10, 2008, 11:17:34 PM »
ground clearance..
« Reply #7 on: April 11, 2008, 05:04:51 AM »
British makers used to do "bolt on" sidestands which invariably bolted off and the paint people made a fortune re-doing all the fell over tanks etc
c15racer
« Reply #8 on: April 11, 2008, 06:20:07 AM »
mines also been cut off but i have a spare, i wouldnt MIG weld it on, id make sure its TIG'd for strengh.
I was thinking about doing away with the centre and just having the side? i was worried about catching the centre stand on left handers, as ive read a few times its possible to catch it?
Offline crazypj
  • I'm brill, me
« Reply #9 on: April 11, 2008, 07:34:44 AM »
Moreover, why would you not just unbolt the sidestand if you hate it that much?  These are the things that boggle my mind.
Most of the mounting brackets stick out far enough to ground out and lift either front or rear wheel, 500 four is particularly bad IMHO, probably why they moved mounting on 550F (CB500F hangs off front of frame)
 Its not generally a problem for road use but if you fit better tyres and/or suspension it can get pretty serious.
PJ
« Reply #10 on: April 11, 2008, 07:37:19 AM »
My frame where the sidestand had been cut off is about 4 3/4 inch off the ground, And I can still slide the forks up another inch or two for the drags :o.. so no ..I could not ride it with it there.
Early bikes did not have feeler balls on the pegs, some like having the c-stand hit as a warning + be able to lube chain and remove wheel easily.
To whoever thought it has to be tigged on, are you going to reweld the whole frame?
« Reply #11 on: April 11, 2008, 07:40:11 AM »
To answer, yes bolt ons did exist, but I think they were longer (for a narrower Brit frame) and still needed to be welded to prevent moving.
Fix the old one.
Hey 1080 has 2 on his bike, right and left :o.. maybe get one from him..
Offline squirley
« Reply #12 on: April 11, 2008, 07:49:32 AM »
If you need a new one, I cut one off of my 550 frame for the reasons above and I may be able to locate it; I changed to a yoshi exhaust, and the hang down protrusion on the 550 kickstand is horrific looking.  I just welded on some new tabs to hold the kickstand up inside the frame rails below the engine.  Can't even really see a kickstand unless you really look for it.
Offline mystic_1
  • 1970 CB750K
« Reply #13 on: April 11, 2008, 07:51:41 AM »
Woah, that's a great idea.  I'd end up using the right-side one all the time, just to be different  :D
mystic_1
Offline mystic_1
  • 1970 CB750K
« Reply #14 on: April 11, 2008, 07:58:58 AM »
JUST to be different :D
mystic_1
Offline kayaker43
« Reply #15 on: April 11, 2008, 11:28:33 AM »
Never saw a clamp on stand,.. Doubt if that would work unless it had some fancy bracketry to stabilize it and not just friction clamping?
Offline squirley
« Reply #16 on: April 11, 2008, 11:52:39 AM »
If you are refering to my old kickstand, let me make sure that I can find it.  If I do it is yours if you pay the shipping.
If and when I do find it, (I will look tonight), I will take some pics and post em up.
Offline FunJimmy
  • Who you calling
  • Vancouver
« Reply #17 on: April 11, 2008, 02:39:31 PM »
Squirley
Don't I remember you promising a full build report?
Well!!!!!
FJ
Offline squirley
« Reply #18 on: April 11, 2008, 03:02:47 PM »
I have been meaning to get to puting up a build thread but I just get so busy fabing things, then removing them and then redoing that it monoplizes all my free time. :'(
Plus, I picked up an H1 that I have tried to get going ::)Just what I needed, more projects
Offline squirley
« Reply #19 on: April 13, 2008, 08:00:30 PM »
I didn't forget about the kickstand.  I did find it and snap a pic and will post it as soon as I find the camera link cables.  However, the kickstand no longer has the spring, but I bet they are probably not too hard to find.
