Author Topic: Bent center and side stands  (Read 971 times)
Offline ProudGecko
« on: April 10, 2008, 04:30:11 PM »
It appears that my center stand (its mount point) is tweaked because the bike looks like it is leaning a bit when its up on the center stand.  The side stand also seems to be bent because it doesn't rest on the flat part like it should, instead it rest on the elbow of the stand which makes the bike lean over farther when its on the side stand.
Does anyone have any suggestions on ways to straighten these?
1973 Honda CB500f
Re: Bent center and side stands
« Reply #1 on: April 10, 2008, 08:28:23 PM »
C-stand..
Get some help to hold the bike (may take 2 people) with wheels on 2x4s and centerstand down. Get a long bar in between the centerstand legs and bend it back..
« Last Edit: April 10, 2008, 10:12:31 PM by 754 »
Offline Bikebuff
« Reply #2 on: April 11, 2008, 05:05:11 AM »
+1 to 754's recommendation.
While your buddies are helping you, make sure take a look underneath at the C-stand and sidestand mounts.  When I had my bike on the sidestand it leaned over severely.  I bought a different sidestand thinking it was the culprit, when in fact a PO rewelded the mount incorrectly.   ::)  As a result, I've taken the sidestand off and just use the centerstand .
« Reply #3 on: April 11, 2008, 05:29:40 AM »
You sidestand should actually sit on the "elbow". If it sat on the "foot" it'd fall over too easily on soft ground. Cheers, Terry. ;D
