Author Topic: Carb Question: What is this?  (Read 771 times)
destroyer
« on: April 11, 2008, 07:34:29 AM »
So I have this little white washer sleeve thing sitting with my carbs parts for by '79 cb650 and can't find it anywhere on the parts diagrams.  Where does it go, or is it something that was on my workbench and mistakenly got put with the carbs?
Question number two, Can anyone tell me how the heck to hook up the thin choke relief spring between the two choke arms?  Thanks.
Offline crazypj
  • I'm brill, me
Re: Carb Question: What is this?
« Reply #1 on: April 11, 2008, 07:37:42 AM »
What diameter is it? Would it fit on throttle shaft? I think it locates the operating arm under top cover
PJ
Offline kslrr
  • There is always a Blaster when there is a
  • Raising her up right!
« Reply #2 on: April 11, 2008, 08:47:37 AM »
That nylon spacer does go on the throtle shaft.  I had rebuilt my '79 carbs last year.  Right now I can't seem to find a pic.  I will take a pic tonight and post it.  To hook up the springs, I kept the #2 and #3 carbs spaced apart (all shafts in place but all carbs loose) and slowly brought the whole thing together while using needle nose pliers and small flat blade screw driver to hook spring.  it was a PITA!
Now  1972 CB350FX (experimental v2.0)
        1981 CB650c Custom with '79 engine (wifes)
        1981 CB650 engine
        2004 HD XL883C Custom
        1977 Yamaha XS750D (in progress)
Then 1972 CL175
        1964 Yamaha YGS-1T
No ride is a Bad ride
destroyer
« Reply #3 on: April 11, 2008, 09:42:01 AM »
The nylon spacer is not the one that goes on the throttle shaft.  It won't fit around the throttle shaft, but it will fit around the choke arm?  The outside diameter of it is slightly larger than the throttle shaft.
destroyer
« Reply #4 on: April 11, 2008, 02:01:42 PM »
If I did, they'd have a hard time finding that bushing too once I showed them where to put it.
