I worked on my cb750 all day yesterday and just as I was nearing the end of my day, I decided to put my newly charged, fresh high performance battery in. I did not realize, that this new battery had the poles in the opposite positions as my old battery, so the first thing I did was hook up th leads, just as they were with the old battery, because they are naturally set up (length wise) to fit that way. Bad Move! I shouldn't have assumed that this new battery, even though it looked basically the same, was set up the same.
Now for the Smoke..... I hooked up the negative lead on my bike to the positive pole on the battery. I was in the process of trying to bolt on the positive lead,(to the neg pole on batt.) and then the smoke started rolling off my wiring harness. The smoke was coming from the harness plug that is located right next to the grounding bar where all your grounds are connected. I really know very little about electrics. I freaked, and immediately unplugged the terminal plug that had smoke rolling out. It was then that I realized the mistake I had made. I unhooked the battery cables, switched them to the proper positions, checked the fuses and now nothing works.
Has anybody ever encounterded this? I have checked the fuses and they seem to be intact. Where is a good place to start? Is there more fuses than the main, headlight, taillight, that I'm not aware of?
