Author Topic: Steering Bearings?  (Read 5774 times)
Offline mkramer1121
Re: Steering Bearings?
« Reply #25 on: December 18, 2006, 04:36:19 AM »
I just pryed/popped mine off with a screwdriver.  The 750 one looked like grabge afterwards, but the GL one is reusable, you just have to tap/work your way around it carefully.
Offline pae
    • Phil Edwards CB650 pages
« Reply #26 on: December 18, 2006, 05:03:46 AM »
Ta very much - that's all the encouragement I need to just get on with it  :).  I'll be replacing all bits so damage ain't a worry (unless it's to the stem  :( )
Regards, Phil
'79 CB650  .... | ....  XJ600 electric drag racer  .... | ....  T W M C
It takes a lot of practice to sound like yourself
Offline Jinxracing
  • It's hot shit, not
  • '70 CB750 K1
    • The Hairy Nickel
« Reply #27 on: December 18, 2006, 09:07:09 AM »
I was about to ask the same question...thanks for the info!
Jim
–Captain Horatio Hornblower
www.thehairynickel.com
Offline crazypj
  • I'm brill, me
« Reply #28 on: December 18, 2006, 11:08:32 AM »
The rubber seal will stretch and come off without damage to it. then you can knock the bearing off quite easily.
PJ
Offline pae
« Reply #29 on: December 21, 2006, 06:38:29 AM »
As the man says, seal easily pulls over the lower race (grip the edge with pliers and ease it out and up and over), and then the lower cone came off - required a fair few heavy taps, but it came off just fine.
thanks to all, another job done,
regards, Phil
