Author Topic: 78' CB750 Rotors?  (Read 1512 times)
Offline zeus87
78' CB750 Rotors?
« on: April 14, 2008, 11:37:30 AM »
Put comstars on my bike, before i look into a Supersport front end, does anyone know of a rotor that will work on the comstar wheels and match up with the factory front style caliper?  Obviously the comstar rotor is much smaller in diameter and actual thickness, even with it properly spaced im only touching on half the pad.  Thanks
Offline doobiebro
Re: 78' CB750 Rotors?
« Reply #1 on: April 14, 2008, 01:11:48 PM »
The Supersport rotors are indeed almost half the thickness of the K rotors.  The '79K Limited Edition, '79 CB650, and '80 CB650 Custom each came with Comstar mags with the single rotor.  There may be a few other models with the same set-up, but I am not sure.  The Comstar single rotor is the same (or very close) thickness as the '78K spoked wheel rotor.
Offline zeus87
« Reply #2 on: April 14, 2008, 09:56:40 PM »
yeah, it is close...but now close enough.  I have very poor performing brakes.  I guess im going to look into a new fork assembly.  Thanks
Offline eurban
« Reply #3 on: April 15, 2008, 04:25:05 AM »
Right.  If you are going with Comstars, makes sense to upgrade to the F2/F3 models front brakes as well.
Offline Geeto67
  • A grumpy
« Reply #4 on: April 15, 2008, 06:46:40 AM »
or the DOHC 1981-82 dual piston calipers since they work so so so much better than the SOHC F stuff.
Maintenance Matters Most
Offline zeus87
« Reply #5 on: April 15, 2008, 07:20:34 AM »
now will those dual piston calipers line up and mount to a set of Supersport forks?
Offline mick750F
« Reply #6 on: April 15, 2008, 05:36:54 PM »
   They will but you need the mounting brackets from the dohc as well.
Mike
Glosta, MA
Offline zeus87
« Reply #7 on: April 15, 2008, 06:29:35 PM »
so what should i do? look for F forks or a new front end with discs?
Offline zeus87
« Reply #8 on: April 16, 2008, 08:53:50 AM »
i located a 1982 sc750 custom parts bike.  It has the whole front end on it, would this be something to look into?  Will the forks take my triple tree or would it be a full swap?  let me know what you guys think.  I can snag it for $75... Thanks
Offline zeus87
« Reply #9 on: April 17, 2008, 12:10:04 AM »
anyone?
