Author Topic: Oil Filter Bolt 750 k8  (Read 1144 times)
Offline clearcan
  • The bike works well to transport kayak paddles
« on: April 14, 2008, 07:54:01 PM »
I bid on a new oil filter cover set up on feebay that came with a new bolt as well.  The bolt was all that i was really interested in since mine was all hacked.  So i opened up the package a few months later, today, when i was doing my oil change and noticed that the bolt is about 1.5 inches longer than the original that came out of the bike.  in my package there was another piece that looks like its a housing that goes in between the oil filter cover and the engine that would take up the additional 1.5 inches (it has an additional o-ring on one side too).  Does anyone know about this set up and will it work with my 750 k8?
1978 750K
Roscoe
Re: Oil Filter Bolt 750 k8
« Reply #1 on: April 14, 2008, 08:18:35 PM »
I have the same set up on my 78 F2. I think it was a mod for the 77-78 bikes. Not sure if it applied to the K8 though.
Cheers
Roscoe
Offline MrZxp
« Reply #2 on: April 14, 2008, 11:25:48 PM »
Yes, Roscoe is right i believe... the extra "oil cooler" bit is only on the "F"....
Since you have the whole set up, it might fit? Try it? Or not?
From Hondachopper.com
CB750E-2600014 and CB750GE-1000014
F2
New cylinder head with bigger valves (34/31mm i/o 32/28mm), larger combustion chamber, larger carb mount rubbers, stronger cam chain, new camshaft, harder valve springs, new retainers, cotters, new pistons compression ratio 9/1. New rod big end bolts and bearings, harder clutch springs, additional fins on crankcase, larger fins on oil pan,
"oil cooler" - finned plate between oil filter case and engine. Final drive 15/43 or 14/43.
Cheers, Phil
« Last Edit: April 14, 2008, 11:33:53 PM by MrZxp »
09 Boulevard M90
SOHC4 Member #3336
Offline eurban
« Reply #3 on: April 15, 2008, 04:32:29 AM »
It will fit fine. . . .BTW oil filter bolts are plentifully available as aftermarket pieces.  They are cheap too.   These typically come with a larger 17mm head to help avoid the rounded off bolt issues.   The larger bolt head also helps you to overtorque them too :)
Offline clearcan
« Reply #4 on: April 15, 2008, 06:52:57 AM »
alrighty then, i'll see if i can just pick up a new one on the cheap, if not i'll just wing it with the f setup
1978 750K
« Reply #5 on: April 15, 2008, 10:09:24 AM »
Just make sure you got that spacer (part number 9) in there
Offline clearcan
« Reply #6 on: April 15, 2008, 10:42:50 AM »
hmm i'm not seein that part number 9 spacer.  i'll give another look, any idea's of what i could make one of these out of?
1978 750K
Offline nteek754
  • 1973 K3/750/836/70 1970 750 chopper 1973 cafe
« Reply #7 on: June 04, 2008, 04:56:26 AM »
Hey all like eurban said it will fit just fine on all sohc 750s. im thinking may where as the Fs were black so they added this extra cooling thang. I put one on my sister 74 750 K I just transfer the oring from the old filter so it gets replaced every oil change. instead of just leaving that one on the cooler. so it gets a kinda fresh one. I have often wondered just how many degrees cooler they make um run . but honda must of had a reason. Its like the  real plumbed up coolers we can run I have some biker buddies (harleys)  that say oh you dont need a cooler on those. HUH! no its not over heating BUT I do think over the long haul it lengthen engine life certainly on my 836 power plant have fun Craig in Maine
seven fifty four ever its not the destination its the journey Ive been collecting these old dinasours for 33 years . they are quite an ICON
Offline gtyler5
« Reply #8 on: June 04, 2008, 07:50:16 AM »
I have a 78F that needs the longer oil filter bolt, if you don't end up using that one, shoot me a pm and I will buy it from you for a reasonable price or maybe trade some stuff  ;D
1976 CB750F cafe
1978 CB750F (in progress)
1993 CB750 Nighthawk
