Author Topic: 78 cb550 carb help  (Read 1450 times)
Offline gene03079
78 cb550 carb help
« on: April 15, 2008, 05:37:14 PM »
Anyone have a good manual on the 78 CB550 carbs?
These beasts are a bit different than most I have worked on. So far I have had them out twice and just cant get the hang of them. I plan on pulling them one more time this week to make sure they are clean. I have the floats set at 14 but I then read 12.5 may be the correct number. The screws on the bottom engine side are set at 1.5 turns out. I have found getting them off and on with the stock airbox gets easier after a few tries.
78 CB550 74 CB550  71 SL175  08 Harley Ultra
Honda CL 175 racer  1977 Honda MT125R race bike 65 CB160  69 SL350
Re: 78 cb550 carb help
« Reply #1 on: April 15, 2008, 06:01:36 PM »
The only manual for these, that I know of, is the Honda Shop manual supplements.  (Chapter 19).
These cover the 77 K3 PD carbs (same general type as yours)
However, for the 78 with the #42 pilot jets, the Honda spec book says 12.5 mm float height for the 78 model.
The Carb FAQ has this information.
« Reply #2 on: April 16, 2008, 08:40:07 AM »
Yup only Manual is the supplement to the original Honda and to be honest it aint that good and it only sez 77 but what it does say is:-
Main jet 90
Air jet 130
Slow jet 38
Slow air jet 150
Jet needle 3rd groove E2349F
Float height 14.5mm
pilot jets normally 1 1/2 turns out
These are for the 550K3, there was a 500K3 in some countries and those numbers are different
Offline bozo4onion
« Reply #3 on: April 16, 2008, 10:02:01 AM »
Good luck. How many times till removing gets easier???? I am converting to stock and was amazed at the difficult installation w/orig. box. And....I was just curious how my mighty 550 would run w/o pods and w/ the stock box. Well hours later I found out it runs much better w/stock system. I think the pods were the only modification I had (no re-jetting). But now I have to remove it again to reset floats and change leaking gaskets etc. Any tips?? BTW I think I have a copy of the Honda carb. manual if you want me to email it to you. Large file.
« Last Edit: April 16, 2008, 10:28:18 AM by bozo4onion »
« Reply #4 on: April 16, 2008, 10:04:42 AM »
This is from the Honda Spec booklet...
Offline gene03079
« Reply #5 on: April 16, 2008, 02:15:51 PM »
Thanks guys. This week end I pull again and recheck them.
I think I will try the level at 12 mm  that may be part of the problem.
« Reply #6 on: April 16, 2008, 09:50:00 PM »
You have the advantage on me TT as the 78 never got to uk so there is no paperwork! There were some sold in 78/79 BUT they were "leftover" 77's
Offline gene03079
« Reply #7 on: April 20, 2008, 04:02:26 PM »
I pulled the carbs again today. I am getting good at removing them now. During the disassembly I found someone forgot to tighten down the mains during the last cleaning. I re cleaned everything and set the floats to 12.5. This time I also tightened the mains down as they don't work when sitting in the bottom of the bowls. After reassemble I gave it try. Bike started right up and ran fairly smooth. A little more syncing and I think they will be fine.
Thanks for the help guys. You made a hard job easy.
