Author Topic: Front Drive Sprocket Torque  (Read 1545 times)
Offline Burke
« on: April 16, 2008, 05:33:50 PM »
I can't seem to find this torque call out fo rthe front drive sprocket. It did not seem to be in very tight.
Anyone know?
Online Johnie
Re: Front Drive Sprocket Torque
« Reply #1 on: April 16, 2008, 06:07:02 PM »
Not sure what bike you are talking about, but my KO book says 5.1 - 10.8 lbs-ft.
1970 CB750K0 - Candy Ruby Red
1976 GL1000 Sulphur Yellow
Oshkosh, WI  USA
ws6transam
« Reply #2 on: April 16, 2008, 06:35:04 PM »
Wow, only 5 - 10 ft.lb.
I just finished a conversion to a 530 chain, and when placing the front sprocket in position, I used a 12mm, 1.4 inch drive craftsman socket with some 242 loctite on the bolt. I put the socket onto the bolt, then hand-spun the rear tire (while in neutral) until the socket cinched up against the frame. Yeah, that's probably 16 ft.lb, give or take a couple.
...and I figured that it was loose due to inattention by the previous owner!
« Reply #3 on: April 16, 2008, 06:52:08 PM »
Johnie is talking about the smaller bolt size..
Helps to mention the bike its on..
Offline Burke
« Reply #4 on: April 17, 2008, 05:21:27 AM »
Sorry, 77' 750K
Online Johnie
« Reply #5 on: April 17, 2008, 05:25:36 AM »
Yes, I was talking the smaller bolts.  I also forgot to mention to put some locktite on those too.
Oshkosh, WI  USA
