Author Topic: CONFLICTING ANSWERS !!!! Re-jetting a 1998 1100 ace and changing fluids HELP -  (Read 1037 times)
Wannabe
Thanks for reading. I have a 1998 shadow ACE VT1100C. Do I need to re-jet the carbs for a Cobra exhaust? And Do I have to flush the radiator fluid? I have been getting conflicting answers from various shops here. Thanks much !!!
Offline nickjtc
  • I was numero dieci
  • Yamaha XT500 'Gromit'
Unless it is due on the service schedule I don't think you have to flush the coolant if you re-jet the carbs.
Nick J. Member #3247
2008 Triumph Tiger 1050
1977 Suzuki GS750
Offline 333
  • Time for change
Nick is right.  There is no connection between the coolant and a possible jetting issue.  If it hasn't been changed in 10 years, it's probably overdue.
There is only one way to be absolutely sure on the jetting.  Install the new pipes and ride it for a while.  Then read the plugs.  The only thing that could be hurt is the plugs, and they are relatively cheap.  But first, does Cobra have an opinion?  And is everything else stock(air filter in particular)?  Typically, a "not so radical" pipe won't require a jetting change.  When selecting a pipe for a sport bike, there is usually a selection of baffles depending on how radical you want to go, because horsepower is the main reason someone does this to a sport bike.  Not too much selection with the cruiser bikes, as the intended results are usually just a new look and minor tonal changes.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
