Author Topic: Valve spring apprehension  (Read 972 times)
Offline fmctm1sw
« on: April 19, 2008, 06:28:41 PM »
Looking at my valve springs, there appears to be coils closer to each other towards the bottom.  The "closer coils" are supposed to go toward the guide right?  I ask because one sprung out and I got to looking at it....
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
jtrain
Re: Valve spring apprehension
« Reply #1 on: April 19, 2008, 06:34:17 PM »
put it back like the others
Offline 750goes
  • it will live
« Reply #2 on: April 19, 2008, 06:38:21 PM »
I'm pretty sure it is tighter coils towards the head - but I've been known to be wrong more than once as well... :)
tighter coils means more resistance at that end - I believe both inner and outer springs should face the same way...
Offline 750goes
  • it will live
« Reply #3 on: April 19, 2008, 06:49:21 PM »
Yes- Honda Common Service manual indicates
"For valve springs with varying pitch, install the valve springs with the narrow pitch end facing down" Section 9-14.
Offline City Boy
« Reply #4 on: April 19, 2008, 09:35:57 PM »
Hey 750goes.Do you have any idea if a copy of the common service manual can be scored anywhere?     Thanks
'52 Kiekhaefer Mercury Rocket Hurricane KG4H
'70 750/RC 1000 Original Owner
'83 1100F
Offline City Boy
« Reply #5 on: April 19, 2008, 09:40:06 PM »
Cancel that thought 750goes.Found some info in thread further along.Sorry    Rock On
'83 1100F
