Author Topic: Cleaning intake and exhaust ports  (Read 2477 times)
Offline fmctm1sw
« on: April 20, 2008, 04:22:21 PM »
What is the most cost effective way to clean these up?  I'm not going for a full porting job or anything, I just figured I'd clean it up while it's all apart...
Quote from: 754
Quote from: inkscars
This is not a pod thread
1973 CB350F
1973 CB350G
1975 CB550K
1983 GL650I
1994 Honda TRX300
1999 Honda TRX250
Re: Cleaning intake and exhaust ports
« Reply #1 on: April 20, 2008, 06:07:36 PM »
 Bead blasting is what I use. Put bolts in all the blind holes.
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #2 on: April 20, 2008, 07:14:32 PM »
Those ports are just asking to be ported out  8)
come ooooon  ;D, you've already got the head off
just kiddin'  +1, bead blasting's the best but if you don't have one handy, scrape the hard stuff off with a tool of some sort but be careful, the aluminum is easily gouged. Finish up with some scotchbrite and some brake cleaner (wear gloves) or degreaser. My new favorite cleaning tool is a toothbrush. cheap and work well but they may not fit in them little ports.
 Matt.
Gallery at:
Offline mystic_1
  • 1970 CB750K
« Reply #3 on: April 20, 2008, 07:19:01 PM »
Low-fume EZ-Off works pretty well to loosen the baked on carbon.  Don't leave it one too long (like overnight) cause it will discolor the aluminum and you'll have to clean THAT off.  A couple of hours, brush with a BRASS brush (so as to not scratch the aluminum) and rinse.
mystic_1
- John Augustus Shedd
Offline 75750SS
  • 75 750F, 2010 Concours ABS
« Reply #4 on: April 20, 2008, 08:58:01 PM »
I use a brass cleaning brush, the kind used to clean a shotgun (cheap).  Attach it your drill use compressed air to clean out the dust.  Careful the first time you blast it with air.  A lot dust will blow out.
Offline 75750SS
« Reply #5 on: April 20, 2008, 09:00:38 PM »
Forgot to mention, get a smaller gauge for the smaller tight spots.
