Author Topic: 77 550k rebuild  (Read 4086 times)
Offline BlindJoe
77 550k rebuild
« on: April 21, 2008, 07:04:15 PM »
Here's how it looked last August:
Started tearing the motor down over winter break to replace the head gasket:
http://farm3.static.flickr.com/2107/2207105119_d5e67b7984.jpg?v=0
http://farm3.static.flickr.com/2108/2207105279_23788f401d.jpg?v=0
Did a poor man's port and polish, lapped valves, did a lot of painting and polishing.
Going back together this last weekend:
After some more work this weekend it should be ready to go for the summer  ;D
Thanks again for the pipes Ryan, they look great!
Re: 77 550k rebuild
« Reply #1 on: April 21, 2008, 07:16:57 PM »
Nice job, you'll turn heads for sure.
Offline neudl
Re: 77 550k rebuild
« Reply #2 on: April 21, 2008, 08:05:42 PM »
So I've gotta ask - how the hell did you get the engine so clean?
Offline BlindJoe
Re: 77 550k rebuild
« Reply #3 on: April 21, 2008, 08:32:47 PM »
First I disassembled the top end and soaked it in the sink filled with hot water and "simple green" for a few hours. For the combustion chambers and ports I used oven cleaner and a brass brush; then I used the dremel tool with the scotch brite wheels. For the mating surfaces I scraped off the old gaskets with a razor blade, then cleaned the surface with simple  green, scotch brite pads, brass wool and wiped them down with naptha. For the fins I used simple green and scotch brite pads. And a lot of patience and determination.
Offline FunJimmy
  • Who you calling
  • Vancouver
Re: 77 550k rebuild
« Reply #4 on: April 23, 2008, 07:56:54 PM »
Stunning engine.
Nice job.
Offline fastbroshi
  • Puppet
Re: 77 550k rebuild
« Reply #5 on: May 04, 2008, 11:45:19 AM »
So why didn't the carbs you sent me look like that??  ;D
Just call me Timmaaaaay!!!
Offline BlindJoe
Re: 77 550k rebuild
« Reply #6 on: May 26, 2008, 07:53:44 PM »
So I've been done with it for about a month, just haven't gotten around to posting pics, here's some I took today at the arboretum, its been running like a champ ;D
Offline fastbroshi
  • Puppet
Re: 77 550k rebuild
« Reply #7 on: May 26, 2008, 08:43:25 PM »
Looking sharp, and all stock as well. 8)
Offline drackett_19
  • '75 cb550K
Re: 77 550k rebuild
« Reply #8 on: May 27, 2008, 03:29:32 PM »
Very nice! that engine is beauty.
Chad
Re: 77 550k rebuild
« Reply #9 on: May 27, 2008, 03:52:48 PM »
Wow.  My bike is gonna get jealous of me gawking at this beauty.
Offline BlindJoe
Re: 77 550k rebuild
« Reply #10 on: June 05, 2008, 07:23:36 PM »
Thanks for the comments!
Here's a really short clip that got even shorter because youtube cut it off, whateva:
[youtube=425,350]<object width="425" height="344"><param name="movie" value=" src=" type="application/x-shockwave-flash" width="425" height="344"></embed></object>[/youtube]
« Last Edit: June 05, 2008, 08:44:01 PM by KottkeHead »
