Author Topic: Tank Dent repair with pictures.  (Read 11052 times)
Offline kghost
« on: April 21, 2008, 09:51:41 PM »
Well....The CB400F I bought had a big crease in the fuel tank.
I've seen a few go on Evilbay for 200+ dollars and well I'm a cheap SOB....
SO I had to fix the one I had....
Stranger in a strange land
Offline mystic_1
  • 1970 CB750K
Re: Tank Dent repair with pictures.
« Reply #1 on: April 21, 2008, 10:03:06 PM »
NICELY done!  Good job, that's a tough place for a dent, and the lines in the last pic look great.
mystic_1
- John Augustus Shedd
Offline kghost
« Reply #2 on: April 21, 2008, 10:05:06 PM »
mystic_1
Yeah just a wee bit of plastic filler....I hate bondo but sometimes ya have to use a little bit...
One day I'm gonna learn how to use lead solder.... ::)
« Reply #3 on: April 21, 2008, 10:07:11 PM »
wow.... very nicely done,  your metal skills never cease to impress me.
Offline azuredesign
  • Knupping pin
« Reply #4 on: April 22, 2008, 03:52:17 AM »
Impressive, thanks for the photos! Is that technique harder with smaller diameter dents?
Offline kghost
« Reply #5 on: April 22, 2008, 06:25:48 AM »
No its actually a whole hell of alot easier with small dents.
It was a bloody big dent with a crease....
Small dents are a 1-2 hr job and thier ready for paint.
« Reply #6 on: April 22, 2008, 02:03:16 PM »
my first thought when i saw the first pic was "no way" that dent was huge with a crease that has to match the oppisite crease,
again , very impressed (i'm not very good with slide hammer myself)
Offline 750goes
  • it will live
« Reply #7 on: April 22, 2008, 02:31:42 PM »
great job - do you do house calls - and what are your rates??
very nice job and looks as good as new
did you braze those rods onto the tank ??
Offline inline4
« Reply #8 on: April 22, 2008, 05:31:02 PM »
DITTO!!!!!!!!!! ;D
America Needs To Get Its Balls Back!
Offline keiths
« Reply #9 on: April 22, 2008, 06:05:00 PM »
Nice!!!
I think lead is easier than plastic. I'm too impatient for plastic. I just can't seem to wait even one minute. Start to sand too soon and it crumbles, too long and it's too hard. It has been a long time since I used or needed lead, but as I remember, it was fast and easy.
Offline kghost
« Reply #10 on: April 23, 2008, 03:12:46 AM »
DITTO!!!!!!!!!! ;D
Good lord if I did it for one I'd have to do it for everyone.... :D
I've thought about doing a few...but it seems the postage to send it to me would negate any saving...cost just as much to find someone decent local.
The little strips of wire are actually tig welded on.
When I do one tank I usually do at least two or three...just to have a spare.
I might do some for members at a later date.
After I finish the 400, the Cafe under construction and restore my gold K2....
Offline KB02
« Reply #11 on: April 23, 2008, 04:52:13 AM »
So, what, exactly is the process?  do you just pull up on the wires?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
tbone
« Reply #12 on: April 23, 2008, 05:04:06 AM »
A stud welder works well for this. Studs are threaded and toy can screw a slide hammer on them. Much less grinding than using a mig welder to connect pulling rods. IMHO
Offline kghost
« Reply #13 on: April 23, 2008, 07:39:02 AM »
No Mig...TIG.
Offline mystic_1
  • 1970 CB750K
« Reply #14 on: April 23, 2008, 10:12:20 AM »
No Mig...TIG.
Even more impressed now :)
mystic_1
Offline JLeather
« Reply #15 on: April 23, 2008, 10:14:19 AM »
Man, I didn't know HarborFreight sold a stud welder.  Guess I'll add it to my list.
Offline kghost
« Reply #16 on: April 23, 2008, 12:40:32 PM »
No Mig...TIG.
mystic_1
Have a deep attachment to aluminium...what can I say  ;D
I've found the stud welders hit or miss.
A good one is faster than my method.
A bad one is just frustrating.
I know the Eastwood unit is a good one. If I'm too cheap to buy a tank then I'm prolly to cheap to buy a $300 stud gun from eastwood when I have a perfectly good welder.
I've no experience using the Harbor Freight unit.
Harbor Freight can sure be hit or miss. I've gotten some good stuff cheap and some cheap stuff cheap.
Offline coyotecowboy
  • Easily Distracted
    • American Legion Riders Post 69 Medicine Lodge, Ks
« Reply #17 on: April 27, 2008, 05:55:46 AM »
What kind of attachment do you need on your slide hammer to hold onto the rods?  My tank has a pretty good sized dent on the left side, right under the frickin badge.  PO had in the garage with too much other stuff, the 750 usually lost those battles :(
The adventure begins when things stop going as planned - Glen Heggstad
http://www.alrpost69.com/
Sunrise Orange 750 K2
1981 Husqvarna 430 XC, "Inga"
troppo
« Reply #18 on: April 27, 2008, 06:01:22 AM »
its kinda like the jaws on a drill, to grab the thin shaft of the pin
Offline kghost
« Reply #19 on: April 27, 2008, 07:47:30 AM »
Mine is a extremely cheap slide hammer.
In fact its designed to work with screws.,..,.as in put the screw thru a hole then thread the rod of the puller onto it.
I drilled a hole in the tip and use a cut off wood screw as a shim/clamp.
Pulls wire fine.
  • Easily Distracted
« Reply #20 on: May 06, 2008, 07:28:03 PM »
"its kinda like the jaws on a drill, to grab the thin shaft of the pin"
I think I can rig up something like that, thanks for the help!!
Offline kghost
« Reply #21 on: May 06, 2008, 07:29:05 PM »
[/quote]
I can snap ya a picture of mine if you need it
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #22 on: May 07, 2008, 08:10:59 AM »
       Great job on that tank Tim! 8) Like others have said, you SURE seem to have a way with metal. ;) Ya thinking of a sideline there? ???
                             Take care,  Bill ;)
Member # 1969
