Author Topic: Rear light Question  (Read 1554 times)
Offline Burke
Rear light Question
« on: April 23, 2008, 09:44:56 AM »
On my 77' 750K are the rear Signal lights suppose to be lit when the bike is running?
« Last Edit: April 23, 2008, 09:53:15 AM by Burke »
Re: Rear light Question
« Reply #1 on: April 23, 2008, 10:02:24 AM »
I can't stand it...
I'm outa here.
Offline Burke
« Reply #2 on: April 23, 2008, 10:05:44 AM »
I can't stand it...
I'm outa here.
Whoa, didnt mean to scare ya off. I know there suppose to be on, but thata my problem.
jdigga
« Reply #3 on: April 23, 2008, 10:07:39 AM »
Actually, they're not...
Offline Burke
« Reply #4 on: April 23, 2008, 10:09:59 AM »
really??
On all the other bike I have owned, they are.
Or do I just  have the wrong bulbs in there (I replace with what the PO had in there)
jdigga
« Reply #5 on: April 23, 2008, 10:12:26 AM »
If they're red, ok.  Amber, or any other color besides red, in the rear for running lights is a no-no.
jdigga
« Reply #6 on: April 23, 2008, 10:30:27 AM »
See pages 8-9: http://www.michigan.gov/documents/vehicle_equipment_requirements_8583_7.pdf
Hmm, according to this Michigan vehicles can have an amber stop lamp. ???  Odd, but that's what it says.
But the answer to your original question is still no--they're not wired for that.
« Last Edit: April 23, 2008, 10:33:10 AM by jdigga »
Offline Bodi
« Reply #7 on: April 23, 2008, 01:06:29 PM »
I think there's actually wiring in the harness to do this, but all the bikes I've seen have single filament bulb sockets in the rear signals, no provision for marker lamps. You can swap around socket units if you can find ones that fit, I suppose, and have rear markers. Here in Ontario you can only have red tail lights though... probably not enforced but certain members of the constabulary love to stop bikes for any "offence" so I like to follow the rules.
Offline mystic_1
  • 1970 CB750K
« Reply #8 on: April 23, 2008, 02:27:41 PM »
Rear running lights would exacerbate battery drain at idle, unless you used LEDs.  Just a thought.
mystic_1
- John Augustus Shedd
« Reply #9 on: April 23, 2008, 02:28:02 PM »
It was a popular mod back in the day to wire the rear turnsignals to act as running lights. The US DOT bans the use of any color but red in the rear.
« Reply #10 on: April 23, 2008, 06:05:48 PM »
I can't stand it...
I'm outa here.
Question/topic has been asked and answered many times in this forum.  Just caught me in a bad moment. Kinda like the Chinese water drop torture...
Good luck!
Offline Jakoba
  • I'm far from a CB750
« Reply #11 on: April 24, 2008, 09:12:29 AM »
I have 1978 750K.  :o :o
Mine are set up for indicating only. Factory?......not really sure. :P
Were the original rear indicator lenses red or amber? ??? ???
Thanks
Jako
Member #4500
"See the ditch, see the ditch, in the ditch"
« Reply #12 on: April 24, 2008, 09:17:29 AM »
The rear turn lenses were amber when stock.  Any wire diagram should tell you the rears were for turn signaling only.  The fronts, two filament bulbs, the rear single filament.
Yawn,
Offline Burke
« Reply #13 on: April 24, 2008, 09:36:51 AM »
This info did help. I did more research and most likely I have a bad ground.
Offline Jakoba
« Reply #14 on: April 24, 2008, 11:08:18 AM »
Come one twotired, how are us newbies ever gonna learn if we don't ask silly/stupid questions. ;D ;D
Cheers ;)
Jako
Member #4500
Offline dusterdude
« Reply #15 on: April 24, 2008, 11:28:08 AM »
tt,you kill  me man :D
mark
1972 k1 750
1949 fl panhead
1 1/2 gl1100 goldwings
1998 cbr600 f3
« Reply #16 on: April 24, 2008, 12:23:49 PM »
It's not a silly or stupid question.  Just one that has been asked and answered numerous times on this forum.  It's fatiguing, that's all.
If the rear signals blink when selected, it's not a bad ground.  It's working as designed.
76 cb550
« Reply #17 on: April 24, 2008, 02:54:44 PM »
I'm bad.  I tend to ask a question and then search for an answer while I wait for responses.
Offline chrislib
« Reply #18 on: April 24, 2008, 03:52:16 PM »
but can I fit a 750 engine in 550 frame???.....AHA!!!
Chris...closet Idlefiddler
#1975
1973 CB750K...CANDY BACCHUS OLIVE
Offline mystic_1
  • 1970 CB750K
« Reply #19 on: April 24, 2008, 03:59:44 PM »
Only if you mount Cheng Shen tires and use synthetic oil.   ;)
mystic_1
