Author Topic: GW1000 or CB900?  (Read 1640 times)
Offline donny
GW1000 or CB900?
« on: April 23, 2008, 03:31:42 PM »
I see 1000GW's  and CB 900 for sale occasionally rather cheep, but of course they could be a money pit. Is one much better than the other? Which is a better bike for long distance cruzin?  Much better than the 750?
2007 Husqvarna self propelled lawn mower    1976F    1971K    1974K      1990 FXRS-SP
Offline Aaron J Williams
  • Old Biker
  • Member # 725
    • Dude's Garage
Re: GW1000 or CB900?
« Reply #1 on: April 23, 2008, 04:17:01 PM »
The wing would be the better long distance bike but the CB 900 would be the better sport tourer. Both are nice bikes but comparing either to a SOHC 750 would be like apples to oranges. Shaft drive vs chain, air suspension vs springs, CV carbs vs mechanical slides, cushy seat vs worn out foam, the list goes on and on. You should get one of each and decide by ride. ;D
There are old bikers and there are bold bikers but there are very few old, bold bikers.
Quote from: Gordon
Not doing what you can to make your bike ride-able during the best riding months of the year kind of defeats the purpose of owning it in the first place.
Offline 333
  • Time for change
« Reply #2 on: April 23, 2008, 04:47:48 PM »
What CB900? A C or an F?  I've always wanted an earley Wing, but a friend got a CB900C and had me get it going.  I think 10 speeds(C) are way cool.
CB350F0  "Scrouching Tiger"
CT70K0    "Sneezing Poodle"
www.alexandriaseaport.org
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #3 on: April 23, 2008, 05:26:07 PM »
         All depends on what you want to do with it. What do YOU have in mind? ???
Member # 1969
Offline kghost
« Reply #4 on: April 23, 2008, 07:07:46 PM »
Too bad I don't have any more GL1000's  ;D
Stranger in a strange land
Offline 78 k550
« Reply #5 on: April 23, 2008, 07:10:20 PM »
Kgost,
what did you get out of her?
Paul
Paul
Littleton, CO
76/77 CB 750F,
76 GL1000 LTD
84 GL1200 Standard
Offline kghost
« Reply #6 on: April 23, 2008, 07:48:10 PM »
Kgost,
Paul
Enough not to lay awake at night.... ;D
Pm send
Offline donny
« Reply #7 on: April 24, 2008, 09:22:56 AM »
[All depends on what you want to do with it. What do YOU have in mind? ]
...this is the question I asked:
 quote "Which is a better bike for long distance cruzin? "
I haven't ridden either the GL1000 or CB900.  appears the CB900 is a better bike..
  • Old Biker
  • Member # 725
    • Dude's Garage
« Reply #8 on: April 24, 2008, 02:15:52 PM »
The wing would be the better long distance bike.
Quote from: Gordon
Offline crazypj
  • I'm brill, me
« Reply #9 on: April 25, 2008, 08:00:56 AM »
 Not in my opinion.
The 900 is easier to work on but usually does need work.
Cam chains, generators and starter clutch are weak points
 Good bike when its all fixed though.
PJ
Offline donny
« Reply #10 on: April 25, 2008, 08:23:47 AM »
 ;D   thanks for the info...still undecided...well....am now leaning toward a GL1000,, they are cheeper anyway...whatever i find, I am sure the ad will say  (need  some carb work.
I hear there are certain years to stay away from.
  • Old Biker
  • Member # 725
    • Dude's Garage
« Reply #11 on: April 25, 2008, 10:01:31 AM »
There are a lot of stories about GL1000 carbs being junk but they are great carbs if clean and adjusted right. The have small idle circuit passages which makes it a little harder to get them clean but it can be done. I'm rebuilding a set for a GL1100 right now and the passages came clean without any problems. They do suck to remove from the bike but are not too bad after you get them out. The only wing I have heard to be trouble was the GL1200 due to charging system problems. I prefer the GL1100 just because it has a little more power than the 1000 and none of the problems of the GL1200. I have heard of guys getting 200,000 miles out of a wing and I have seen them with 100K+ miles on them still going strong. Wings use timing belts instead of chains, they have valve adjusters instead of shims like the CB900 has and they are liquid cooled instead of air cooled like the CB900. Ultimately either bike is a good choice but I would test drive both before making a choice.
Quote from: Gordon
