Author Topic: Stupid question about timing/circuit completion  (Read 882 times)
Offline narcoticrex
« on: April 23, 2008, 05:24:20 PM »
If the plug wires arent hooked onto the plugs, can I still adjust timing, or does cause the circuit to be open and not read?
basically, the plug wires are too short until i fix them, but can i do the timing now?
"i love the smell of cooked beaver in the morning...it smells like....victory."
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
Re: Stupid question about timing/circuit completion
« Reply #1 on: April 23, 2008, 05:41:55 PM »
If you're going to static time using a test light,voltage meter,or buzzer it won't matter if the plug wires are on or off. If you're going to use a timing light............you're outta luck, you'll kill the battery trying to crank the engine enough,or wear out your right leg. ;D ;D ;D
