Author Topic: Second coat with Por 15  (Read 1875 times)
Offline livetoskate
  • "Get busy living or Get busy Dying"
« on: April 25, 2008, 04:26:24 AM »
Someone mentioned doing a second coat with the por 15 product.
A couple of people I know were very happy with there results with one coat.
What do you guys think?
Thanks
78 cb750K , 73 CB750 x2, Yamaha dt360 & 250
Offline KB02
Re: Second coat with Por 15
« Reply #1 on: April 25, 2008, 04:57:48 AM »
I did one coat and it worked on mine. Extra coat for extra protection?
1978 CB750K Project
2000 Ducati ST2
...and a pedal bike
Join the AMA today!!
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
« Reply #2 on: April 25, 2008, 05:23:34 AM »
It's like a second condom...  one's 99% effective but some people want that extra 1% for peace of mind.
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
« Reply #3 on: April 25, 2008, 06:14:57 AM »
Trouble is, once exposed to the air, the surplus POR 15 must be discarded (according to the instructions) so you'd have to use a fresh can, which could get expensive. One coat should do fine. ;D
Offline livetoskate
« Reply #4 on: April 25, 2008, 06:15:59 AM »
When would I apply the second coat?
« Reply #5 on: April 25, 2008, 06:17:27 AM »
Why do you think you'll need to?  :-\
Offline livetoskate
« Reply #6 on: April 25, 2008, 06:24:37 AM »
Someone recomended it on my other post
I would definitely do a double coat... I noticed a huge difference between one coat and two.  With one coat, there are parts of the liner that are so thin that it's almost transparent.  With two, it really looks robust.
I am only going to do one coat and see how it works,I'm sure It will be just fine.
« Reply #7 on: April 25, 2008, 06:31:48 AM »
That was for Kreem, but it's an entirely different coating. One coating of POR15 will be fine, unless you've got big holes, in which case they should have been patched first. Cheers, Terry.
Offline livetoskate
« Reply #8 on: April 25, 2008, 06:34:44 AM »
Thanks alot
« Reply #9 on: April 25, 2008, 06:36:33 AM »
No worries mate, let us know how it turns out. ;D
Offline johnyvilla
« Reply #10 on: April 25, 2008, 06:38:11 AM »
One coat worked for me. That stuff is so thick that two coats might unearth imperfections.
Offline livetoskate
« Reply #11 on: April 25, 2008, 03:30:57 PM »
One coat looks great,man that stuff works good.
Offline cb350twin
    • http://mail.google.com/a/sohc4.net/
« Reply #12 on: April 25, 2008, 05:16:09 PM »
It depends on which POR 15 your using and where. The original POR 15 is UV light sensitive and if exposed it sunlight it will fade or yellow. So your will need to add a another coat of something like black cote POR 15. If it's where sunlight won't get to it then one coat of just the normal POR 15 will work.
1975 CB 750 K5
1972 CB 350 Twin K4
1972 CB 500 Four K1
