Author Topic: 1976 cb750 popping at idle  (Read 2626 times)
muddykart04
« on: April 26, 2008, 06:59:55 PM »
hi, my 76' cb750 is popping at idle only im wondering if it is running lean on the pilot circuit. everything has been cleaned many times on the carbs and synced. bike runs perfect besides that. i also have the kerker 4 in 1 exhaust on the bike ( the carbs are all stock jets ) my air screw is out 1 3/4 turns. any suggestions??? exhaust header leaks???
Offline scondon
  • Mmmm......tasty bugs
Re: 1976 cb750 popping at idle
« Reply #1 on: April 26, 2008, 09:15:30 PM »
  Enter "exhaust popping" in the search bar and you should find no less than thirty threads to help give you some ideas :)
Offline JAG
  • '74 CB750K, '72 CB500, '76 550K
« Reply #2 on: April 27, 2008, 08:24:17 PM »
very true..  But had the same problems, try to tighten all your connections from the mufflers all the way to the headers, mine was doing it and it is usually caused by air escaping somewhere.
good luck with it!
Cafe Racing is mainly a matter of taste. It is an atavistic mentality, a peculiar mix of low style, high speed, pure dumbness, and overweening commitment to the Cafe Life and all its dangerous pleasures. I am a Cafe Racer myself, on some days - and it is one of my finest addictions. ~H. S. Thompson~
