Author Topic: 78 CB750F2 Valve Removal  (Read 3398 times)
UKCB750F2
« on: August 16, 2005, 08:47:09 AM »
Hello all,
I'm in the process of rebuilding the engine for the first time and need to know if it's possible to removal the valves from the head using a home-made tool or do I have to buy the Honda item?
Thanks
Online SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: 78 CB750F2 Valve Removal
« Reply #1 on: August 16, 2005, 08:52:28 AM »
Assume you mean the valve spring compressor.
Any compressor will do as long as it will reach (most car compressors won't). I bought a motorcycle one in the 70's and have used it ever since - it wasn't the Honda tool but just designed for OHC bikes.
SOHC4 Member #2393
2015 Tiger 800 XRT
1971 CB500K0 (US Model)
Williamsd
« Reply #2 on: August 16, 2005, 11:59:22 AM »
Made one out of a C-clamp.
Soldered a modified plumbing fitting to the flat face.
Had to modify the clamp a bit to fit over the edge of the head.
« Last Edit: November 26, 2005, 12:34:21 PM by Glenn Stauffer »
Offline Cvillechopper
  • Is just pretending to be an
  • If not for my failures I'd never know my limits
« Reply #3 on: August 16, 2005, 12:02:48 PM »
I bought one at Sear's in the auto tool section in 99' that worked great.  Think it was about $20.
It is the mark of an educated mind to be able to entertain a thought without accepting it.  Aristotle
Offline Lumbee
    • My pics...
« Reply #4 on: August 16, 2005, 01:50:01 PM »
..same here...I just bought one in the spring from Sears...works like a charm.  If it doesn't work, Sears will take it back.  Be advised, the springs on the F model are extra stiff!  Be sure and wear u'r eye protection and watch for flying valve retainers!!! :o
"I'm not a welder, but I play one on HondaChopper.com"
Offline Dennis
« Reply #5 on: August 16, 2005, 04:49:10 PM »
How about some part numbers on those Sears tools, please?
I looked for a while and couldn't seem to locate one that would work on motorcycle heads.
I have been using a C clamp and a small length of galvanized pipe with a section removed from the pipe to access the keepers. Similar to the home made tool pictured above but not soldered together. It works well but is not all that convenient.
Offline Lumbee
    • My pics...
« Reply #6 on: August 16, 2005, 05:06:51 PM »
Offline Dennis
« Reply #8 on: August 16, 2005, 09:51:45 PM »
...not 100%, but this on looks like mine...
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&pid=00947704000
This is the one I have
http://www.sears.com/sr/javasr/product.do?BV_UseBVCookie=Yes&vertical=TOOL&pid=00947627000
Thanks guys. Unfortunately the Sears site is "currently being reconfigured". I hope those links work when they are finished screwing around with it.
Offline scondon
  • Mmmm......tasty bugs
« Reply #9 on: August 16, 2005, 10:36:59 PM »
Here's one at JC whitney. I bought a slightly different one from them for 18.99 but couldn't find it listed. Works great.
http://www.jcwhitney.com/autoparts/ItemBrowse/c-10111/s-10101/p-100000206184/mediaCode-ZX/appId-100000206184/Pr-p_CATENTRY_ID:100000206184
« Reply #10 on: August 16, 2005, 11:25:17 PM »
Ooooh, that's nice!  ;D
