Author Topic: getting the motor out!*&^%$ honda cb550 k2  (Read 1206 times)
TWISTED KID
« on: April 27, 2008, 07:48:27 am »
Im ripping out a  motor and cant get it out....?    Yes all bolts cables and electric are disconnected.   I tried tipping the bike over and letting gravity work its magic but the studs from the exhaust hit the frame and hold it back from falling out.   Im about to cut off the studs from the exhaust in my next move...but would hate to ruin a motor....even though this motor is locked..
any suggestions?
THanks ???
Offline kghost
Re: getting the motor out!*&^%$ honda cb550 k2
« Reply #1 on: April 27, 2008, 08:04:44 am »
Remove the studs.
Turn them out don't cut them
Stranger in a strange land
TWISTED KID
« Reply #2 on: April 27, 2008, 08:19:45 am »
I tried using a vise grip without luck on the studs.   I guess I can wd40 them let'm sit for a bit and then try it again.
thanks.
ps nice collection of bikes... ;D
Offline kghost
« Reply #3 on: April 27, 2008, 08:47:54 am »
thanks.
You can double nut them
Or get a stud puller.
TWISTED KID
« Reply #4 on: April 27, 2008, 08:56:52 am »
I will try the two nuts.
Stud puller???   autozone?
thanks
« Reply #5 on: April 27, 2008, 09:16:51 am »
You don't have to take out the exhaust studs to remove engine from frame on a 550.  You do have to take off the oil filter.  The carbs have to be off, and left crankcase cover.  Engine removes from the right side of frame.
Offline greenjeans
  • 1972 CB750K2
« Reply #6 on: April 27, 2008, 09:31:29 am »
Yep....the studs do not have to come out.  Removing the oil pan will give more clearance as well.
TWISTED KID
« Reply #7 on: April 27, 2008, 02:45:12 pm »
oh left sidecover. . .
i broke off a couple studs so far.
thanks gents.
cheers...and beers
