Author Topic: 1080cc bike?  (Read 28058 times)
Re: 1080cc bike?
« Reply #100 on: May 04, 2008, 07:03:07 PM »
Geez Mike, you're quoting yourself now? Is that like talking to yourself, and then answering yourself back? It might be time for a little "R and R", methinks? Ha ha, Cheers, Terry. ;D
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
Re: 1080cc bike?
« Reply #101 on: May 04, 2008, 08:26:19 PM »
Will a Magna motor fit in a 550 frame?... :D.... ::puts helmet on and hides::
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
eldar
Re: 1080cc bike?
« Reply #102 on: May 04, 2008, 08:39:45 PM »
Maybe if you put it in sideways! ;D
eldar
Re: 1080cc bike?
« Reply #103 on: May 04, 2008, 08:52:37 PM »
I will stick by what I say. A stock cb will not beat a sabre/magna, nor a mild cb. It takes quite a bit to do it. Can it be done? Yes it can, at least in a drag. Once you throw in hard corners? Well I don't think so but I doubt there is any road race between the 2 so it is a Q that will probably never be answered. If there is proof, then link the source, not just a quote.
Now if there is this much work going into the cb, what if the same was done to the v65? While hard to find any data on v65 engine work, I would bet the v65 would consistently beat the cb then.  Just like I would be pretty sure a busa would beat the v65.
Does this mean I do not like the cb? Of course not. I just like the v65 as well. Clearly that is not a crime as many here have bikes other than the cb.
This is the last I will debate it. I stand by what I say as there has been no linked info otherwise, just possible copy/paste.
Offline 1080
Re: 1080cc bike?
« Reply #104 on: May 04, 2008, 09:30:28 PM »
Here's a bike called The Executioner. It had a 900cc kit, stock 1970 cam. The gas tank is fiberglass Bondurant ( 3.2 gal ) and the bike weight 380 pounds. Owned by Bob Exley
I am going to quote because I an not sure if the pics with writing will be readable.
 "The last time Bob had his bike out to a strip was the day after he returned from a run on it that took him more than 800 miles.  Without so much as looking at his plugs, he ran it at Irwindale Drag Strip and turned 10:90 ET with a speed 122.6.  That's moving!"
Motor Cycle World's Special Choppers January 1975.
« Last Edit: May 04, 2008, 09:35:36 PM by 1080 »
Re: 1080cc bike?
« Reply #105 on: May 04, 2008, 09:35:39 PM »
Eldar, nice wriggling.. ::)
Here are direct quotes of what you said;
"The Sabre would blow blow all over the cb even at 1080"
"I posted ona STOCK V65,on the street no CB750 will touch it"
coff.. coff.. look up at the last post.. coff.. coff...
 wonder what that would do at 1000cc?
BTW,  I would be one of the last people to back out of a  dragrace with anybody..  bring it on...
« Last Edit: May 04, 2008, 09:52:24 PM by 754 »
Offline seaweb11
  • 1st Mate &
  • Ride & Smile
    • Playground Directory
Re: 1080cc bike?
« Reply #106 on: May 04, 2008, 10:12:30 PM »
Re: 1080cc bike?
« Reply #107 on: May 05, 2008, 04:49:27 AM »
I'm the only one that listens to me Terry. ;) ;D
Re: 1080cc bike?
« Reply #108 on: May 05, 2008, 04:54:19 AM »
Good post 1080! I like the look of the Executioner! Nice!
Anymore interesting magazine articles like this?
cheers
Andy
Re: 1080cc bike?
« Reply #109 on: May 05, 2008, 05:34:15 AM »
I listen to you Mike, (well, I read your posts at least, I can't hear you from this side of the pond...........) you're still the man! ;D
eldar
Re: 1080cc bike?
« Reply #110 on: May 05, 2008, 06:24:05 AM »
380 pounds? Thats close to dropping 1/3rd the weight of the bike? At that rate, everything had to be lightened. Lot of custom machine work it sounds like. I mean, I suppose if the motor lost weight, it would be down to about 180 pounds or so? That still only leave 200 for everything else. Do you have more info on how that much weight was saved?
I ask that not so much for myself but many here go on the weight loss quest and this might help them out. besides, it is interesting.
754, do you read? I said I was done. but since you are like a tick, you only care about very short distances and only straight lines. I look at the whole spectrum, as such there is no point in debating such a closed person as you.
But i will be at your door if I ever get a v65.
Offline cafe750
Re: 1080cc bike?
« Reply #111 on: May 05, 2008, 06:45:48 AM »
750 motor weighs 175 from the factory...I've got my 75F down to 430 wet, from 530. All I did was change the exhaust, went to a fiberglass seat, some different signals, cross drilled and lightened front brake rotor and a few other small things...no major surgery required...
Roy, Washington
Offline ekim98
Re: 1080cc bike?
« Reply #112 on: May 05, 2008, 07:19:06 AM »
I would like to know more about how you got to 430 wet. I've put my 78 750k on a diet and I've gotten down to approx. 455 lbs dry. Unless my digital bath scale is wrong?? My 4 into 1 exhaust is only 13 lbs 2 ozs., removed the stock air box for pods, cut the rear foot pegs brackets off, took just over 5 lbs off the stock seat, drilled the front rotor,shortened both fenders quite a bit, have very small turn signals and tail light, no ctr.stand and replaced the stock foot pegs with cbr 1000 r foot pegs, no tach or center light cluster. Granted my rear wheel and tire might be heavier - 16" rim and 5.1" wide tire. I'm really having trouble find places for weight loss, and your down 100 lbs wet. I'm impressed.  :) :)
Patriot Guard Rider - KY. Ride with Respect
78 750k  cafe bike sort of
67 305  Superhawk (working project)
Offline eurban
Re: 1080cc bike?
« Reply #113 on: May 05, 2008, 07:44:30 AM »
Yes I can't quite see the changes you mention adding up to 100lbs.  Stock exhaust was already a 4-1 although a heavy one no doubt.  How confident are you with those before and after weights?
Sorry if I'm being a skeptic here but I strongly doubt that the bike in magazine pic is anywhere close to 380lbs.  I would add atleast 50lbs to that number!. . . . .
« Last Edit: May 05, 2008, 07:46:59 AM by eurban »
Offline cafe750
Re: 1080cc bike?
« Reply #114 on: May 05, 2008, 08:37:54 AM »
I do have to admit that I weighed the bike on a WSDOT truck scale, with a half tank of fuel, I just whipped in off of the freeway to find a rough weight on the bike... now I have to go and weigh it on a certified scale somewhere...
Roy, Washington
Re: 1080cc bike?
« Reply #115 on: May 05, 2008, 09:10:37 AM »
That seat probably weighs 30 lbs. ;)
eldar
Re: 1080cc bike?
« Reply #116 on: May 05, 2008, 10:42:56 AM »
If I remember correctly, the engine is actually close to 200 pounds if not over, including starter. That was actually posted here a few times. Something like 214 pounds.
Re: 1080cc bike?
« Reply #117 on: May 05, 2008, 05:40:47 PM »
Thank God for that, I thought I was losing my strength, as I get older I'm finding it harder to pull one out of the frame and lift it up onto my work bench! ;D
eldar
Re: 1080cc bike?
« Reply #118 on: May 05, 2008, 08:26:12 PM »
Well then you should be the weight expert on these motors! ;D  Do you know what the weight is?
Re: 1080cc bike?
« Reply #119 on: May 05, 2008, 08:52:10 PM »
W/o carbs, but with starter, is closer to 168 lbs than 200 lbs.. ;D
eldar
Re: 1080cc bike?
« Reply #120 on: May 05, 2008, 09:24:09 PM »
I found something Bob posted about a year ago and the weight was listed as something like 176 with oil. So that is significantly less than 200. Dump the oil and starter and stator and I would guess the weight is closer to 120 - 130 pounds. Hell that is less than the EQ rack I get to lug around once in a while!
Offline 1080
Re: 1080cc bike?
« Reply #121 on: May 05, 2008, 09:49:09 PM »
Another pic for Andy750.
 This bike has R.C. Engineering parts (315 cam and big bore), Webers, and a Kerker header.
 The body parts are also fiberglass.
Re: 1080cc bike?
« Reply #122 on: May 06, 2008, 01:40:58 AM »
Yeah mate, Farking heavy! ;D
Re: 1080cc bike?
« Reply #123 on: May 06, 2008, 04:16:47 AM »
Thanks for that 1080. I like the style of the seat on this bike. I prefer this type of fiberglass bodywork compared to the Tracy bodywork. Amazing paint job as well. Thanks for posting! Keep them coming if you have them  ;) I like the mods and history of a bike if you know it.
Cheers
Andy
Re: 1080cc bike?
« Reply #124 on: May 06, 2008, 04:21:17 AM »
That's one tough looking 750! ;D
