Author Topic: Wheel runout question  (Read 3305 times)
Offline smccloud
    • Shaun's blog
« on: April 27, 2008, 02:03:34 PM »
Ok,
Some of you may remember me asking for help relacing my rear wheel.  I have that done and am now in the process of truing it up using a tire crayon; or at least getting it close for now until I can "borrow" my dad's dial indicator.  I know the dial indicator is best, but I could afford the tire crayon and trust my dad when he says I can do it using it.  That and for some reason I am pretty decent at measuring the distance between the crayon and rim as its spinning.  What is the max distance I should shoot for when setting the runout using this (crappy) method?  I know its been mentioned before, but i can't find it now........
CB750 K2
Quote from: Hush
Who needs a mobility scooter when you've got a SOHC4?
Gun/Cars/Motorcycles/Computers/Insert Next Expensive Hobby here
Offline shoemanII
  • just another bike nut
Re: Wheel runout question
« Reply #1 on: April 27, 2008, 02:39:22 PM »
trued both my rims to between 1 to 1.25mm in both directions but it took awhile, 'cause it was my first time.  i trued up/down first, then side to side.  am sure my poor wife got tired of hearing tink, tink, tink, tink, tink, tonk, tink, tink, tink, etc.  ;D
good luck, be patient and step away if need be.  don't forget to oil your nipples!  (hey, somebody had to say it).
bobp
'96 ducati carb'd 900ss/cr
'72 dt2
'77cb550k frankenberry:  '77cb550k frame, '78cb550k engine, '78cb550f tank, unknown front-end
« Reply #2 on: April 27, 2008, 11:01:25 PM »
Max of 1/8 inch (3mm) for both up and down and side to side.
Forget the dial indicator its WAY too accurate
Offline chippyfive50
  • NO PEE ON TEPEE
    • thesweetimpala
« Reply #3 on: April 28, 2008, 05:42:05 AM »
you'll go mad with the dial unless you started with a fresh round rim...I'll second the 1/8th!
SOHC Member#4000
71' 500K0 #1021237--E1108327
78' 550
72' 750K2(sold to "Craig")
74' 750K4 #2306334--E2303422
73' CL175
http://gallery.sohc4.net/main.php?g2_itemId=14013
troppo
« Reply #4 on: April 28, 2008, 06:15:58 AM »
cant beat the feel of oiled nipples :D :D :D :D ;D
Offline merc2dogs
« Reply #5 on: April 28, 2008, 06:50:49 AM »
 I'll say go for the 1/8th too.
  A lot of people can't detect anything less than 1/4 inch out either way, and a lot of what you can detect depends on the suspension. I aim for 1/16th just because I can. You don't need perfect concentricity.
 My prefferred 'tools' are my finger and a sharpie, or dry erase marker, rough it in using my finger as a gauge, then use a sharpie for fine tuning.
 Have several dial indicators and agree, they're far too accurate and more difficult to use. With a sharpie they leave a visible mark, so you know what needs tightened where. That speeds up the whole process. mark, adjust, wipe it off and go again till you're happy with the results.
Ken.
Offline crazypj
  • I'm brill, me
« Reply #6 on: April 28, 2008, 07:01:19 AM »
about 3mm side to side max and 2mm up and down, MOT is 1/8"
 You WILL feel vibration with this amount off run out, even at 40~50 mph (forget the misleading 'most people cant feel less than 1/4 run out".)
 Your 'crappy method' will get you to within 0.010"~ quite easily as long as you don't go nuts tightening spokes in one place only (and remember to loosen opposite if you need to rather than snap spokes)
 If you haven't used a dial indicator previously its not the easiest thing to use.
You can see the effect of a quarter turn on nipple and it may not be in direction or place you wanted so can actually be a distraction.
PJ
Offline smccloud
    • Shaun's blog
« Reply #7 on: April 28, 2008, 11:17:56 AM »
ok, i'm at around 1mm side to side.  probably more up and down though.  i will "borrow" one of my fiance's sharpies tonight since i can hold that closer to steady using the chain guard than i can the tire crayon on the outside of the rim.
CB750 K2
Quote from: Hush
Offline LoopsAndLogic
  • Dang IT!!!
« Reply #8 on: April 28, 2008, 02:25:38 PM »
Not to hijack your post, but does anybody know what the run out on a 400F should be in inches?
 I'm finally at ease using my dial indicator.
They work great! And just to let you know, you can get a really nice and accurate one at Harbor Freight.
LL
My rides:
75' 76' Honda CB400F Super Sports
86' Honda XR600R for Street Madness
84' Honda Interceptor VF500
Past Rides:
80' Honda CX500C Fully Dressed
81' Honda CB650C very nice!
83' Kawasaki KZ550 A3
78' Hondamatic 400 Hawk
80' 81' 82' Honda GL500 Silverwing Insterstate
Offline smccloud
    • Shaun's blog
« Reply #9 on: April 28, 2008, 06:35:28 PM »
LL
probably the same as for a 750.  just convert the mm to inches (25.4mm in one inch).
as for me, i got it all done tonight.  put the tire on then noticed the *(^*(& arrow was on backwards.  I pulled the tire off, put it back on and damned if i didn't wreck my brand new tube :(
sense i am not sure how much riding i will get in before i order a new set of tires (gonna replace the front to try to get rid of a nasty shake when i let off the gas) i just put a can of fix-a-flat in it for now even though the can said not to.  come "economic stimulus" check time i will order a new set of tires, two new tubes, and a new set of rim straps because knowing my luck i wrecked the back one too.  the one thing that worries me is the minor vibration at 65mph or so, but that could be due to the fix-a-flat as well......
i do have to say that riding when it's 40 degrees out gets very chilly and requires the choke to be left on.
CB750 K2
Quote from: Hush
Offline shoemanII
« Reply #10 on: April 29, 2008, 03:53:57 AM »
be very careful about that "nasty shake when i let off the gas".  that's a classic description of headshake.  unless you or the PO has dropped the forks in the trees, you may have loose/worn steering head bearngs.
bobp
'72 dt2
Offline smccloud
    • Shaun's blog
« Reply #11 on: April 29, 2008, 05:50:41 AM »
bobp
i think its due to the front tire having been on a yamaha xs650 before it went on my honda (not known for its good front tire wear).
i think the vibration is due to my dumbass not switch gears when i went from measuring axial runout on the inside instead of the outside of the rim.  i proceded to tighten the spokes where the sharpie marked the rim, instead of loosening those and tightening the other ones.
CB750 K2
Quote from: Hush
Offline crazypj
  • I'm brill, me
« Reply #12 on: April 29, 2008, 09:03:22 AM »
LL
With a DTI you can easily ge to 0.010" or better
PJ
Offline smccloud
    • Shaun's blog
« Reply #13 on: April 30, 2008, 06:03:53 AM »
well, i rode into work today.  got a little chilly at 36 degrees, and the vibration that appears at 65 doesn't leave by 80 either :(  i think i need to do a little more work truing the wheel up.
CB750 K2
Quote from: Hush
Offline crazypj
  • I'm brill, me
« Reply #14 on: April 30, 2008, 06:50:43 AM »
Check wheel/tyre balance.
Rears are often overlooked for balancing but tthey have a major effect on handling
PJ
Offline smccloud
    • Shaun's blog
« Reply #15 on: April 30, 2008, 07:58:27 AM »
PJ
i will worry more about that when i get a new rear tire.
CB750 K2
Quote from: Hush
Offline mystic_1
  • 1970 CB750K
« Reply #16 on: April 30, 2008, 08:00:43 AM »
Have you checked the condition of your wheel bearings?
mystic_1
- John Augustus Shedd
Offline smccloud
    • Shaun's blog
« Reply #17 on: April 30, 2008, 08:03:15 AM »
mystic_1
yep, fine.  there was no vibration 'till i relaced the wheel (and put fix-a-flat in the tube due to my dumbass not being able to mount the tire correct).
CB750 K2
Quote from: Hush
Offline mystic_1
  • 1970 CB750K
« Reply #18 on: April 30, 2008, 08:07:57 AM »
In that case I'd definitely suspect that fix-a-flat, I've never liked that stuff.
Also, check to make sure the tire is mounted straight, most tires have a molded line on the sidewall near the bead, there should be an even gap between this and the rim all the way around, on both sides.
When mounting tires, I like to inflate them to around 5 lbs and then bounce them a number of times, turning the wheel a bit each time.  This seems to help things settle in before inflating to proper pressure.
mystic_1
Offline smccloud
    • Shaun's blog
« Reply #19 on: April 30, 2008, 08:34:59 AM »
mystic_1
yeah, dennis kirk is only like 90 miles from me and they offer free tire mounting with new tires ;)
CB750 K2
Quote from: Hush
