Author Topic: carb help  (Read 957 times)
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
carb help
« on: April 28, 2008, 06:03:29 AM »
I took the screws out and try to drain the carbs....there was dirt in them...I know I need to clean them but I know for sure something is up....three of the four overflows are leaking real bad when the gas is on even when I put the screws back in....why would the overflows be leaking so bad...is it rubber going bad or dirt....
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Offline SteveD CB500F
  • Ride on the Steel Breeze...
    • TVAM
Re: carb help
« Reply #1 on: April 28, 2008, 06:05:34 AM »
Usually tiny bits of dirt in the float valves.
Either tap gently to try to wash then through, or take them out and clean them.
I take it they didn't leak before ?
SOHC4 Member #2393
1971 CB500K0 (US Model)
All modern bikes now gone...
