Author Topic: Petcock woes -> '71 CB500 K0  (Read 1074 times)
Offline dkruitz
    • Dan's Antique Outboard site
« on: April 30, 2008, 12:51:01 PM »
OK, I've changed out all the rubber on my petcock and replaced the bowl as it had a pinhole leak.
It still drips fuel out the lines, and wants to fill the crankcase.  I tried using emery cloth and a smooth surface to lower the height of petcock where the petcock lever mounts - in efforts to have it squeeze the inside rubber tighter - to no avail.
Am I on the right line, or should I just bite the bullet and get a new petcock?
« Last Edit: April 30, 2008, 08:00:34 PM by dkruitz »
Offline dkruitz
Re: Petcock woes -> '71 CB500 K0
« Reply #1 on: April 30, 2008, 08:01:48 PM »
 Can petcocks be "reconditioned"?  Any idea's why it won't seal with new rubber?
Offline drackett_19
  • '75 cb550K
« Reply #2 on: April 30, 2008, 08:43:19 PM »
If its anything like the one on my cb550, you might want to replace the fiber washers that the mounting screws go through. The new petcocks don't come with these washers. I found that out when I bought a brand new petcock and my bike still leaked. It quit leaking after swapping out those washers with some new ones.
Offline dkruitz
« Reply #3 on: May 01, 2008, 07:28:06 AM »
Thanks, I'll check it out - never even thought of those!
