Author Topic: carb boot with pictures (just had idea)  (Read 4344 times)
Offline cb650 bobber
  • Expert I ain't no stinken
  • stupid gloripope
« on: May 01, 2008, 08:42:06 AM »
attatched is a picture of the worst one....they are pretty hard so my grandfather who is my carb man fears it may be hard to get the carbs back on. freaking 21.00 a piece from honda..is there anyway to reuse these or is there a good place to buy them..... are there other models that would use the same boot...
« Last Edit: May 01, 2008, 11:40:47 AM by cb650 bobber »
"I make a point of staying right at the edge of poverty. I don't have a pair of pants without a hole in them, and the only pair of boots I have are on my feet. I don't mess around with unnecessary stuff, so I don't need much money. Von Dutch
Re: carb boot with pictures.
« Reply #1 on: May 01, 2008, 08:49:54 AM »
Definatly NBG, suprised you can get them individual from Honda and yes it will make the carbs WAAAYYYY easier to get back on
  • stupid gloripope
« Reply #2 on: May 01, 2008, 09:01:29 AM »
what is nbg
Offline James
« Reply #3 on: May 01, 2008, 09:05:19 AM »
hey,
www.cmsnl.com have them for 6 euros about $9-$10, with shipping to the us, not sure what that will be, are they for a 550?
http://www.cmsnl.com/honda-cb550k3-four-european-direct-sales_model14672/partslist/E02.html
ok just saw you name, 650 then, will 550 or 750 fit anyway?
NBG - No Bloody Good?
Gort, Klatuu Baratta Nic-DOH!
Offline super pasty white guy
  • I'm not really a
  • 1976 750 F
« Reply #4 on: May 01, 2008, 09:15:05 AM »
15 each from service honda (guessing on the year though).
http://www.servicehonda.com/parts.php?partnumber=16211-426-000&getpart=1&getprice=Submit
spwg
  • stupid gloripope
« Reply #5 on: May 01, 2008, 09:23:41 AM »
1980 cb650c.......sorry I thought I put that in the original post
Offline greenjeans
  • 1972 CB750K2
« Reply #6 on: May 01, 2008, 11:07:33 AM »
I don't know if they will fit your 650, but I have some off a 750 that you could try.  They are old, but still in pretty good shape.
  • stupid gloripope
Re: carb boot with pictures (just had idea)
« Reply #7 on: May 01, 2008, 11:42:05 AM »
what could I use to make the rubber bit more plyable agian...I was doing some research and was thinking of using plastic...rubber dip...to try and redo the carb boots...may be a dumb idea...just thinking.
scadaman29325
« Reply #8 on: May 01, 2008, 11:54:12 AM »
Somebody told me "2 words: Heat Gun".
Sounds good but I have not tried it.
In the same thread "boiling water".
Again no experince...
Later, Phil
  • stupid gloripope
« Reply #9 on: May 01, 2008, 11:54:56 AM »
some one told me soak it in wd40
Offline greenjeans
  • 1972 CB750K2
« Reply #10 on: May 01, 2008, 12:03:18 PM »
There is a product that worked on my airbox rubbers...  Rubber Renue
Before they were unusable - hard as a rock.
I hit them with a heat gun and that softened them a bit, but as soon as they cooled off - hard as a rock again.
Then I found some Rubber at a local electrical supply house and got a few bottles (they were about $4 each)
poured it in a coffee can, heated the rubbers with a heat gun, and dropped them in and put a lid on it - I could only do 2 at a time.
Left them in about 24 hrs.  They swelled up quite a bit larger than original size, but they were very soft and very pliable.
After another day or so, they went back down to the original size...not quite as soft, but DEFINITELY better/softer than
they were before I started.
Offline Gordon
  • 750K1, 550K2
« Reply #11 on: May 01, 2008, 12:08:56 PM »
They're not just hard, they're cracked.  You need to buy new ones.
How many times would you like to do this job?
  • stupid gloripope
« Reply #12 on: May 01, 2008, 12:14:02 PM »
50 times
Offline Gordon
  • 750K1, 550K2
« Reply #13 on: May 01, 2008, 12:17:22 PM »
50 times
Alright then.  Start at the top of the list of things to soak them in and work your way down.  Then when you get to the end of the list and are a professional at removing/reinstalling carbs and the boots are still split and cracked, buy new ones and install them, and be happy! ;D ;D
Offline greenjeans
  • 1972 CB750K2
« Reply #14 on: May 01, 2008, 12:21:21 PM »
just noticed the cracks......buy new ones.
If the boots from a 750 will fit, you're welcome to my old set
Offline Geeto67
  • A grumpy
« Reply #15 on: May 01, 2008, 12:23:16 PM »
Ok, your carb rubbers are cracked and you were getting backfires before...and you are now wondering how to reuse carb rubbers that may be the source of other problems on your bike (and may actually cause damage to your internals).
They are shot and you will need to spend $15-$20 per rubber to get them. Tough noogies, suck it up and spend the money and take this as a lesson in why cheap bikes are really not that cheap and will nickel and dime you to death.
as far as any other rubber pieces that may be hard on your bike - boil them in wintergreen oil and water. Do this outside as it will make your house smell like a giant lifesaver. worked every time for me.
Maintenance Matters Most
  • stupid gloripope
« Reply #16 on: May 01, 2008, 12:29:51 PM »
sometimes I just like to think of ideas...I am planning on getting new rubbers but I wanted my hands on them by friday and it just doesnt seem like any one is stocking them...i want to ride the bike this season I am getting ancy.
scadaman29325
« Reply #17 on: May 01, 2008, 12:39:22 PM »
Neighbor used clear RTV to seal his slightly cracked and weathered boots. He rubbed it into  them.
Skip Ebay, but new ones.
Later, Phil
« Reply #18 on: May 01, 2008, 01:13:53 PM »
How come no one's tried KY jelly?
On their rubbers...
boots...
for their carbs.
Insert innocent looking emoticon here....
  • stupid gloripope
« Reply #19 on: May 01, 2008, 01:19:33 PM »
Offline heffay
« Reply #20 on: May 01, 2008, 03:17:21 PM »
i believe 78k550 may know where to get your boots for around 8 dollars each... maybe, not sure... just the messenger
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
« Reply #21 on: May 01, 2008, 06:55:56 PM »
Bobber, $21 isn't cheap, but at least they're still available! Some boots...are like they say in the credit card comercial "priceless". The ones I need can't be bought for any price.
  Save your pennies and buy new ones. Even if you do soften them up,they'll still give you problems with those cracks.
.........Paul
Offline Gordon
  • 750K1, 550K2
« Reply #22 on: May 01, 2008, 07:43:59 PM »
Better yet, buy two sets and vacuum seal one set in plastic.  That way, in 30 years you'll have an unobtainable set to replace the now old and cracked ones with. :)
kevio
« Reply #23 on: May 01, 2008, 08:40:00 PM »
Most custom hose shops can make whatever you might need.  I had a radiator hose on a Range Rover custom made.  Cost about $50 compared to about $250 from the dealer at the time.  Just take them your old ones and see how much it would be to have them "rebuilt".  I was living in Houston at the time and just looked up "hose" shops in the phone book.  If that doesn't work then you can always do what I'm doing and toss the old airbox setup and go with velocity stacks.   ;D
Offline Blueridgerunner
  • CB650 no longer, but do have an 87 GL1200
« Reply #24 on: May 02, 2008, 01:32:02 AM »
I'll look around the shop, I think I may have some for a 650 that are in a lot better shape. You can have them for the shipping.
Said James "In my opinion,  there's nothing in this world, beats a '52 Vincent and a red headed girl"
Laissez les bons temps rouler
