Brown/red stripe is the fused power for the headlight. It starts from the key switch vicinity, goes through the fusebox and up to the headlight on/off switch.
Blue is Hi beam, white is Lo beam.
Gray is the flasher signal wire from the flasher relay. It goes up to the L/R switch.
