Author Topic: Clutch advise needed  (Read 1174 times)
Offline dramsell
« on: May 02, 2008, 08:14:21 AM »
I am trying to revive a 78 CB 750F.  This bike has sat indoors since 1991.
The clutch needs to be looked at (won't go into gear) and the back brakes do not work.
In the manual it says to shift into 5th gear and use the back brake to hold the motor still.
I borrowed a spanner to take the nut off and I have no way to hold it.  Tried wood through wheel but nothing works.
Any ideas?
Also: does this nut turn  like a normal thread or is it reversed?
I had to use an impact driver to loosen the cover screws.  I will have to purchase new of these.
Thanks
Dave
Offline ken736cc
  • When the cops pull me over, I usually let them off with just a warning.
Re: Clutch advise needed
« Reply #1 on: May 02, 2008, 09:35:25 AM »
Hi,
 It sounds like you may not have a clutch problem. The gears can be shifted even if the clutch does not disengage. Can you get any gear to engage while rocking the bike back and forth?  If you can get the bike in gear, you can immobilise the rear wheel and use the spanner to remove the clutch nut. This is a standard thread, counter clockwise to loosen.
 If you cannot get any gear to engage, then you may have a problem with the shift mechanism.
Hope this helps.
K0 sandcast(in process of restoration), K0 diecast, K0 cafe racer
BMW R69S daily rider, 71SL350, 71 SL100, 63 SS50
Offline mystic_1
  • 1970 CB750K
« Reply #2 on: May 02, 2008, 09:43:44 AM »
Hi,
Hope this helps.
+1  I'd consider popping off the mission cover and examining the shifter mechanism.  There are several small springs and such in there that sometimes like to go on walkabout.
mystic_1
- John Augustus Shedd
Offline Tower
  • Only at conception could I have been called a
  • My personal time machine: 1973 CB750K3
« Reply #3 on: May 02, 2008, 10:12:32 AM »
+1 on the advise so far.  Indeed @dramsell, you may want to hold off on any clutch work at all, until the transmission/shifter issue is resolved.  Afterall, the clutch may be in perfect working order.
Offline dramsell
« Reply #4 on: May 02, 2008, 10:42:36 AM »
What is the mission cover?  I am a real newbie to mechanics.
Dave
Offline mystic_1
  • 1970 CB750K
« Reply #5 on: May 02, 2008, 12:17:57 PM »
Aka shifter cover.  It's the one that your gearshift lever connects through.  The cover on the left side, rearward of the alternator cover, forward of the front sprocket cover.  Later 750's have the gearshift pattern stamped into it.
Honda calls it a "mission cover" for some reason.  Perhaps a contraction of "transmission"?
mystic_1
