Interestingly enough, my new Triumph Rocket 3 only runs 8.9:1 compression (lower than a CB750) but requires a minimum of 95 RON fuel?
I certainly haven't tried anything lower yet as it hasn't had it's first service, (tomorrow) but I'm wondering why a relatively "low compression" engine needs top grade (and top dollar) fuel? Do any experts out there have a clue? Cheers, Terry.
Because there is more to required octane than just compression ratio. My old Yamaha R6 with 12:5 compression that revved to 15K RPM required only regular fuel (87 pump octane in the US), but many very low compression air-cooled twins require premium and still tend to ping in hot weather.
Big pistons and low RPM are the reasons in this case. The Rocket 3 has huge 765cc pistons and runs at ultra-low RPM. Despite liquid cooling it's very difficult to ignite such large volumes of mixture at slow speeds without getting big variations in mixture across the combustion volume which causes pinging.
Everything else being equal, high CR, low RPM, air-cooling, and carbs tend to ping more than low CR, high RPM, liquid-cooling, and fuel injection. And that's just the big factors - there's also combustion chamber design, 2-valve vs. 4-valve, types of valves, bore vs. stroke, etc. etc. etc. There's a lot more to an engine's octane requirement than just CR.
- Mark
