Author Topic: cam clearances  (Read 733 times)
Offline hymodyne
cam clearances
« on: May 03, 2008, 03:58:11 AM »
I've got a 650 cam in my 500/550 head. It moves freely, but there are a few places where the cam lobes come very close to the walls of the head. How much clearance do I need? Should I be concerned about expansion when the bike is hot that might cause the lobes to contact the sides of the head?
hym
Re: cam clearances
« Reply #1 on: May 03, 2008, 04:21:33 AM »
Hym,  it should only be "tight" at the top of the tunnel walls? Could you use a burr in a die grinder and bevel the top of that wall where the clearance is the least.
Re: cam clearances
« Reply #2 on: May 03, 2008, 08:02:32 AM »
Dont eyeball it make sure it has clearance,,lack of clearancs may cause drag if there is a lot of oil there.
Wait and find out before assembling.
Offline Jay B
Re: cam clearances
« Reply #3 on: May 03, 2008, 03:01:18 PM »
Let us know how the 650 cam performs in your bike. I'vew been thinking of doing this for a while.
Jay
'77 CB550K
'74 CB350F cafe
2001 Road King
'73 CB175
Offline squirley
Re: cam clearances
« Reply #4 on: May 03, 2008, 06:18:26 PM »
I am putting together my 550 head right now as I type this.  When I put in the 650 cam, there was no interference, but some of the lobes were very close the cylinder head  cast walls.  I just took a dremel and cleared them out to what the clearance was on a stadard 550 cam.  Right now, I think I cleared them out to have about .010 clearance between the lobe and the head.  I will double check and see what clearance number I wrote down for the 550 cam before I cleared the material.
Re: cam clearances
« Reply #5 on: May 03, 2008, 07:01:42 PM »
Yeah..... it will certainly cause drag if the lobe hits the cover or wall. ??? If it's close to the wall relieve it with a Dremel.
