Author Topic: dunlop d404 reverse tread pattern from front to back ?  (Read 1281 times)
Offline heffay
« on: May 03, 2008, 05:00:44 PM »
elizabeth just got a new front on her srx6 to match the newish rear dunlop d404
the tread patterns are pretty much identical except the front looks like it is mounted w/ the rotation going in the wrong direction... but on further inspection, it is correct.
why?
i would like it better if the tread looked like it was going fast and into the wind instead of backwards.   ???
Offline cb650
Re: dunlop d404 reverse tread pattern from front to back ?
« Reply #1 on: May 03, 2008, 05:21:17 PM »
I noticed this too a few yers back.  Figured it was just my lak of skolin.   ;D ;D
Offline Gordon
  • 750K1, 550K2
« Reply #2 on: May 03, 2008, 06:33:55 PM »
It's not just Dunlops, Avon Roadrunners are like that too.  I guess I'm just used to it.  I always figured it had to do with moving water out towards the edge and away from the tire under the conditions where it's most important.  On the front tire, it's most important to have good stopping traction, since that's where you get most of your stopping power.  On the rear tire, it's most important to get good acceleration traction.
With the "V" shaped treads aimed the way you'd think they look best, they would actually be funneling water towards the middle of the tire when stopping on a wet surface.
