Author Topic: Reducing electrical for kick start only on a 77 cb 550  (Read 2097 times)
Boost_Junkiee
« on: May 03, 2008, 07:20:46 PM »
So how can I just have kick start and what will I be able to eliminate? Will I have to keep a battery? bad idea? I am trying to keep it real basic and I have seen some vespas with kick start only and no battery and wondering if its possible on my bike or has someone done it?
Offline Shenanigans
  • Right turn?
Re: Reducing electrical for kick start only on a 77 cb 550
« Reply #1 on: May 03, 2008, 08:28:06 PM »
You will need a battery. It is an important part of how these bikes electrical systems work.
destroyer
« Reply #2 on: May 03, 2008, 08:30:21 PM »
Please elaborate, I too would like to do away with as much electrical as possible and would like to ditch the battery if I can.
Offline kghost
« Reply #3 on: May 03, 2008, 09:01:23 PM »
Get a magneto...then ya can ditch it.  ;D
Stranger in a strange land
Offline Joel
« Reply #4 on: May 03, 2008, 09:14:20 PM »
What's the minimum size battery needed?
Offline alltherightpills
« Reply #5 on: May 03, 2008, 10:22:01 PM »
There was a recent discussion on whether these bikes will run on a dead battery.  Some useful info in there.
http://forums.sohc4.net/index.php?topic=33354.0
Zach
78 550K
77 550K (in pieces)
71 500K0 (in pieces)
Offline Gordon
  • 750K1, 550K2
« Reply #6 on: May 04, 2008, 03:41:55 AM »
Here you go:
http://forums.sohc4.net/index.php?topic=4412.0
This one goes back about three years, but there's five pages worth of discussion on this one topic.  Even goes into the possibility of using capacitors instead of a battery.  Ultimately, IMO, you're better off just getting a smaller gel or agm battery and ditching the starter motor unless you're dead set on completely customizing the entire electrical/charging system.
Offline kghost
« Reply #7 on: May 04, 2008, 07:45:39 AM »
I did a stripped down diagram for my 750 Cafe...
The wiring basics are the same,
PM me if ya want a copy
Boost_Junkiee
« Reply #8 on: May 04, 2008, 10:25:33 AM »
Thanks for the info! ;D I am going to tackle electrical this weekend and see how it turns out. I want to find out the smallest battery I can run. I will let yall now what I come up with.
kghost I sent you a PM
Offline Mr Johann Vegas
« Reply #9 on: July 20, 2008, 05:56:29 PM »
My Cub runs a 4L-BS, which is a really little one.  It's only a 4AH battery, but likely enough for your needs (and what I intend to use when I start the wiring on my 550, also KSO).
