Author Topic: Preparing for trackday  (Read 6966 times)
Offline voxonda
« on: May 04, 2008, 02:02:51 AM »
Hi there,
Since time is running out for the "Moto classic trophy" on the circuit of Zolder (Belgium) on the 19th of June, have to really start working on my 'Japauto' replica. It is the first time for this bike to get on a circuit, but hope there will be a lot more in the future.
If you like it I will keep you informed about the progress.
Are there more of us using the bike for trackdays?
Cheers, Rob
Re: Preparing for trackday
« Reply #1 on: May 04, 2008, 04:52:56 AM »
Go Rob Go. By all means keep us informed.
My old K3 was a production racer back in the day so no I have no plans to take it back out there, but there is a plan hatching to build some other little missile!
Offline voxonda
« Reply #2 on: May 04, 2008, 11:10:41 AM »
Hi bwaller,
Has been a productive day. Swapped engines, swingarm and carb's. Need to finish the oiltank next.
Cheers.
« Reply #3 on: May 04, 2008, 11:15:42 AM »
I love that fairing bracket on the stem nut, nice work.
 What are the forks, look like old Lockheed or maybe Grimeca?
 What is on the outer edge of the head fins ?
Offline voxonda
« Reply #4 on: May 04, 2008, 11:28:51 AM »
Thanks 754, forks are ø35mm CB900FZ. Front calipers are (new)Grimeca's, rear is Lockheed both with Grimeca master's. Just love them. Damage to the fins, think after a crash. Need to change that, but the oillines to the cooler will hide it from sight. Have a 850 kit with  other head lying around waiting to be installed.
Cheers, Rob
« Reply #5 on: May 04, 2008, 11:46:40 AM »
Sure dont see Lockheeds often, popular pattern though, Performance Machines first cast Calipers fit same pattern.
I think all the Rickmann kits had Lockheed rotors and calipers.. nice original racer stuff..
Offline voxonda
« Reply #6 on: May 06, 2008, 12:35:46 PM »
Hi there,
Need some advice about my preps for the track. Because I use a total loss system, there is no need for all the excessive equipment. Removed alternator and want some advice about blocking the oilpassage in the crank that oils the starterpignon. Used to glue a needle bearing inner sleeve on the crank, although never a problem I wonder if there are other solutions.........
This is my prepped housing that will get a nylon crashplate on it. Hopefully won't need it.
Thanks in advance.
Cheers.
« Reply #7 on: May 06, 2008, 09:01:39 PM »
I welded one crank. I would make an aluminum spacer with a flange towards the main bearing, and .002  smaller than crank. Press it on, try to not get tight against case, mabe a pir of feller guages against case to stop it.
Offline voxonda
« Reply #8 on: May 07, 2008, 08:43:55 AM »
Hi 754, that an possibility. You mean a spacer that's on a press fit? And further no Loctite or what?
Here is one with the Nylon protector.
Cheers, Rob
« Last Edit: May 07, 2008, 08:47:28 AM by voxonda »
Offline voxonda
« Reply #9 on: May 20, 2008, 12:44:13 AM »
Think I do it this way. Inner ring from a ordinary ball bearing and glue it with Loctite 603.
Should do the trick.
« Last Edit: May 20, 2008, 11:25:31 AM by voxonda »
Offline voxonda
« Reply #10 on: May 26, 2008, 12:11:40 PM »
Since, at last, the bodyparts are at the painters (everything "Ford Colorado Red") I'm lying the minimum wiring needed for the total loss circuit. Does anyone of you guys know how big a fuse should be for a Dyna 'S' with coils? Haven't a clue how much it takes from the battery. There is nothing on the bike, no lighting, no starter, just battery and ignition.
Cheers, Rob
Offline turboguzzi
« Reply #11 on: May 28, 2008, 01:00:18 AM »
Hi rob
Took the time to check your pics, nice bike!
Hope you make it to the meeting, looks like there's still some work.....
Would be nice to come to Zolder but I am racing on that weekend too.
What are the discs (with slots) in your last picture? They look pretty trick!
Keep up the good work
TG
Offline voxonda
« Reply #12 on: May 28, 2008, 07:15:48 AM »
Hey TG,
Fairly happy with the bike myself too! I will make it, have to........ am commited to do so or I will be having some 'problems' with my sons!!!! No it'll be ok, the engine runs well, have finished the oiltank just have to spray some VHT-paint on it.
Discs are pretty rare items, they come from Team Marlboro Agostini, back in the 80's. Are ø320 mm in diametre, though Yamaha only seems to use ø300 on the production racers TZ350,500 & 700/750. Maybe a special badge?? Who knows?
Rob
Offline Triffecpa
« Reply #13 on: May 28, 2008, 11:04:44 AM »
Rob
I run a total loss system on my CB750 racer.  I use an in-line blade type fuse.  Go for a 20-30 amp one.  Basically you want the fuse to hold up just short of the bike catching on fire.  Nothing worse than having your race stopped early for a blown fuse.
Tracy
« Reply #14 on: May 28, 2008, 12:15:07 PM »
Rob, never had a fuse on any of my race bikes and never a problem.
Sam. ;)
Offline voxonda
« Reply #15 on: May 28, 2008, 01:34:21 PM »
Thanks for the reply men,
Think I willstart without and measure the amps and then decide to put a fuse in or not.
Hope to have the paintwork back someday next week, so I can do some trailruns.
Cheers.
Offline voxonda
« Reply #16 on: June 06, 2008, 02:32:21 PM »
At last the paint is on!! Just some quick photo's, will make some better ones this weekend.
On Monday the seat will get his leather upholstery. And have to find a screen.
Cheers.
« Last Edit: June 06, 2008, 02:34:04 PM by voxonda »
Offline scunny
  • don't call me expert
« Reply #17 on: June 06, 2008, 02:36:41 PM »
it's looking good
present-CB 650 retro
            VTR1000F3
           XL250S riverbed rocket
           TS250[sold]
           TS185[sold]
           XL125S[sold]
           MT50 (white)
           MT50 (red)[sold]
           KN250/XS400 project
           SL100[sold]
           XL250R
           pedal(pub bike) leaks oil
Offline voxonda
« Reply #18 on: June 11, 2008, 06:13:24 AM »
Again a bid closer to completion, Seat is being upholstered now.
Just need to finish up(???).
Cheers
PS. Need to do somethiong about my the quality of my pictures.
« Last Edit: June 11, 2008, 06:16:12 AM by voxonda »
« Reply #19 on: June 11, 2008, 11:23:53 AM »
Looking good Rob, hope you make it on time  ;)
Sam. ;)
Offline voxonda
« Reply #20 on: June 11, 2008, 11:31:41 AM »
Sam. ;)
Thanks Sam, I will make it on time, no matter what. Seat is to be upholstered and they promised me it will be ready! Just a few minor things and then off we go.
Must say the pic's do the bike no justice. Will have someone make some better ones at Zolder.
What I am very pleased about is the GROWL!!!! of the exhaust. We'll put some 'music' on You Tube.
Cheers, Rob
Offline turboguzzi
« Reply #21 on: June 11, 2008, 02:27:57 PM »
Way to go Rob!
Dont forget to put some sandwiches in the tail's stash box  :) You might get hungry...
Just out of curiosity, what tires are you running?
TG
Offline bill440cars
  • Feeling More & More,
  • Tryin' To Slow Down "Time"!
« Reply #22 on: June 11, 2008, 08:54:31 PM »
       Got in on this one a little behind, but went through all the posts and this is one Great Looking Race Bike that you have build here. 8) ;) As with the others, I wish you well and you certainly have a FINE ride to go on, Rob! ;)
        We certainly are fortunate to have some folks with some great racing bikes, here with the SOHC4! 8) AWESOME Bikes! Rhe attention to detail is incredible!
                                         Take care, Bill ;)
Member # 1969
Offline voxonda
« Reply #23 on: June 12, 2008, 12:50:05 PM »
Way to go Rob!
TG
Hey TG,
With my posture I need to take some food with me, or I won't last.
Tires I am running for now are: Bridgestone BT45 in front and AVON Roadrunner AM 21 in the rear. Think is not the ultimate combo, but have to do for now. Once I sorted out the bike will go for some 'stickier' types. What would you recommand?
Cheers, Rob
Offline turboguzzi
« Reply #24 on: June 13, 2008, 06:11:38 AM »
I am running a 90/90-18 Avon AM20 in front, and a 130/70-18 AM23 in the back.
Might try Dunlop KR124 / KR164 for next season
But first of all you should consider the rim widths you have, useless putting a race compound tire if the rim is too narrow and it squishes it to a worng profile.
Check here:
http://www.avonracing.com/club_page.asp
http://www.avonracing.com/motorcycle_page.asp
Dunlop (scroll down for the "classic range"
http://www.dunloptyres.co.uk/ourTyres/motorsport/motorcycle/
