Author Topic: 750K ignition wiring  (Read 1154 times)
Offline skamania19
« on: August 17, 2005, 11:32:45 PM »
I just acquired a 1977 750K. The ignition was removed for some reason and repaced with a toggle switch. I removed the toggle switch and the wires just fell off. I got a new ignition switch but now I don't know which wire goes where on the switch. There are five connections and four wires (black, red, brown with white, and brown). The switch has two upper connectors and three lower connectors.
Anybody know which wire goes to which connector, and if there should be fifth wire hidden in there someplace?
Thanks.
Columbia River Gorge: Where the wind blows and the rain sucks.
Offline gkw120649
Re: 750K ignition wiring
« Reply #1 on: August 18, 2005, 07:53:04 PM »
Do you have access to a wiring diagram for your 77?
1977 CB-750 K
1978 CB-750 K
Offline skamania19
« Reply #2 on: August 18, 2005, 11:01:10 PM »
Actually I found another parts bike and took the other half of the ignition plug out of that so PROBLEM SOLVED!
