Author Topic: Electrical specs?  (Read 1301 times)
Offline dustyc
  • I don't know why anyone would call me an
  • 1977 CB750K
Electrical specs?
« on: May 04, 2008, 03:32:04 PM »
Does anyone know where to find electrical specs for various models?
I ask because I've heard the 750A's have more electrical output, then I also saw CB900 coils on a 550 and would like to be able to compare specs for different models.
Thanks.
1977 CB750
Re: Electrical specs?
« Reply #1 on: May 04, 2008, 06:27:35 PM »
Thanks.
Best advice on the coils: check the primary with an ohmmeter. Some CB900 coils are 3 ohms, will need external resistors, particularly on a 500/550.
CB750K/F bikes had 210 watt alternators (around 13 amps peak).
OK, "A" guys: what does your spec show? The "A" does have bigger alternator and battery, both. It ate up some of the HP, too.  :-\
Offline 05c50
  • 05c50
    • Classic Motorcycle Solution
« Reply #2 on: May 04, 2008, 07:20:26 PM »
My Honda "A" manual says "0.29 kw/5,000 rpm" and battery capacity "12v-20AH"
..........Paul
