Author Topic: Side Cover Fitment Issue  (Read 964 times)
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« on: May 05, 2008, 12:19:48 PM »
This is a pic of the left side cover on my 350F. The pin is a little off the mark and I can't find anything that's bent or off.
I can get the cover snapped on but it then wants to lift off the top tabs  ???
Anyone else have this experience?
 Matt.
Gallery at:
Offline loonymoon
    • Loonymoon's CB350F enthusiasts gallery
Re: Side Cover Fitment Issue
« Reply #1 on: May 05, 2008, 02:14:43 PM »
Weird!!
Mine does push up on the tabs a little but doesn't force them off.
Offline mattcb350f
  • Hardly a
  • 1974 CB350F
« Reply #2 on: May 05, 2008, 03:03:36 PM »
Weird!!
Thanks LM, Maybe my cover is slightly deformed?
I forgot to mention that the right side cover lines up perfectly.
 Matt.
Gallery at:
Offline merc2dogs
« Reply #3 on: May 05, 2008, 03:31:44 PM »
 One of my bikes had a cover that fit similar to that.
   My solution was t place the cover in position, heat it with a hair dryer, then gently twist it into proper alignment. Hold it in place till it cools down and it should be fine.
 In my case the cover had set in a box for a long while with one side 'hanging' and it apparently twisted through many heat/cold cycles.
ken.
