Author Topic: 16 inch rim on rear question.  (Read 12762 times)
Offline rbirkhan
« on: May 07, 2008, 07:49:39 AM »
I want to run a 16 inch rim on the rear of my 1972 cb 750 cafe proiject. I want the Steve Carpy Cafe look. I would like to get the big and little look. My question is what size rim width should I get. What issues are encountered when going to a much wider tire. I would imagine offset sprockets/ offset brake stay rod  may be needed. I want  a nice handling setup so the front tire and rear profiles must match. I have a stock sized front rim.  I read all the old posts on "max tire size" but most are for stock rim sizes and dont even mention front rim tire sizes.  Also where is a good source for steel rims?
Offline chopstar500
  • King of the Nighttime World
Re: 16 inch rim on rear question.
« Reply #1 on: May 07, 2008, 08:51:23 AM »
A common set-up on the SOHC4 bikes is a 16" x 3.5" (40 spoke) Harley rear rim - anything wider with a stock swingarm will probably be an issue clearance wise. I'm running that same rim with a 140 tire on my CB500 with no clearance issues other than moving the brake arm outboard. Cycle X sells offset sprockets, mainly for use on rigid chopper setups.
For ease I'd go with the stardard HD size that I listed above. If you've got plenty off cash, skills, and money - you can do whatever your heart desires.
« Last Edit: May 07, 2008, 08:53:11 AM by chopstar500 »
Completed Project "Four Pack" - My 1971 CB500 KO - Now For Sale - email me for more info!
Offline Geeto67
  • A grumpy
« Reply #2 on: May 07, 2008, 09:09:49 AM »
why do you want a 16" wheel on a performance motorcycle - it will handle like crap.
Maintenance Matters Most
Offline rbirkhan
« Reply #3 on: May 07, 2008, 06:14:50 PM »
Chopstar thanks for the info thats exactly what I was looking for. Did you run offset sprockets? I dont want to run them unless its a must. That setup looks sweet.
Offline chopstar500
« Reply #4 on: May 08, 2008, 04:13:43 AM »
No offset sprockets - just had to move the brake arm outward about 1-1.5 inches. Absolutely no clearance issues.
Offline rbirkhan
« Reply #5 on: May 08, 2008, 05:19:46 AM »
Good deal now all I need is a 3.5 inch*16 inch harley hoop for the new 140
Offline rbirkhan
Offline rbmgf7
  • 2>4
« Reply #7 on: May 08, 2008, 07:42:36 AM »
you're better off looking for a rim only and search ebay for honda-harley spoke kits
Offline cafe750
  • If you can't fix it with a hammer, it's electrical
« Reply #8 on: May 08, 2008, 07:55:52 AM »
I didn't know he trademarked the 16" rear wheel on a SOHC....its been done for a gazillion years...and so has the "Cafe" style... I know, I know, my screen name is Cafe750, I'm just kind of tired of Carpy getting all of the credit for starting something that he didnt. He does build a pretty bike. I believe in the thinking that a "cafe" should handle well, and go fast, and that the look that a cafe has is just a by-product of the aformentioned efforts... ::takes deep breath::...if you're building something to handle, why a 16" rear wheel? Take a look at all of the roadracers at the time...you won't find the "big and little" look anywhere...search for handling, and you'll find lots about how tire sizes affect handling. Sorry for the rant, no offense intended anywhere.... :)
« Last Edit: May 08, 2008, 08:11:45 AM by cafe750 »
"It's an old motorcycle, the wind is supposed to blow your head around, it's supposed to leak oil, the brakes should suck, and every now and then, it should scare you so bad you piss your pants."
Roy, Washington
Offline rbirkhan
« Reply #9 on: May 08, 2008, 08:03:58 AM »
I dont know about trademarked like you said its been done for years.  He does build nice bikes.
Offline ekim98
« Reply #10 on: May 08, 2008, 08:25:30 AM »
I have a 16" harley rim on my 78 750k and haven't noticed any ill handling because of it. If anything it's the rear tire it's self "chen shing" tire with a ribbed, car type tread that(to flat a  profile) for proper motorcycle handling in the corners. Great for drag race traction tho, really grips good on take offs.
Patriot Guard Rider - KY. Ride with Respect
78 750k  cafe bike sort of
67 305  Superhawk (working project)
« Reply #11 on: May 08, 2008, 08:42:39 AM »
Perhaps the OP is after a hot rod with a cafe flavour...
 I think the 16 rear started, for traction and longer tire life... I can remember when the Yokohama 4.50 x18 came out.. HUGE tire!
 They do fill out the back end in a way no 17 or 18 will, easier to avoid rim damage as well..
 As far as handling, I know you wont see them on roadracers, but I have seen people riding pretty damn fast wuith a 16 rear..
Offline rbirkhan
« Reply #12 on: May 08, 2008, 08:54:26 AM »
no luck searching for the spokes yet even on Egay. This may be a wheel shop visit.
Offline ekim98
« Reply #13 on: May 08, 2008, 08:55:22 AM »
My rear tire is a 5.10 X 16" and it is one big tire. My next tire will be a Spitfire S11 140-90 X 16 to match the front Spitfire. The only reason I haven't changed it was that it was new when I got the bike. There's a lot of rubber on that tire. Probably pretty heavy too.
kevio
« Reply #14 on: May 08, 2008, 09:16:49 AM »
5.10 x 16"?  Did you have to make any adjustments for that width?  I was just wondering if a 4 x 16 would work without mods instead of the 3.5 x 16.  Also, does it have to be a Harley rim?  Can it be some other make 40 spoke 16" rim using a 40 spoke honda/harley kit?  Just wondering how different the hole spacing, etc is.
« Reply #15 on: May 08, 2008, 09:23:11 AM »
5.10 were made for 3.5 rim. The tire is about 120 -130 wide.
Some metric bikes did have 16 in rims, perhaps spoked, so there should be those in aluminum & akront made them as well.
Offline eurban
« Reply #16 on: May 08, 2008, 09:35:41 AM »
These kits come up pretty often on Ebay and they are usually available in ebay stores although for some reason the pickins are slim at the moment.  Here's a link to one that will work.
http://cgi.ebay.com/ebaymotors/Honda-Kaw-Chopper-16-Chrome-Spoke-Set-NEW_W0QQitemZ320246305838QQcmdZViewItem?_trksid=p3756.m20.l1116
Offline goon 1492
  • Sucka Repellant
« Reply #17 on: May 08, 2008, 09:39:20 AM »
I got 16 rear on mine and runnin 5.10 tire, found it out when i was tire shopping.  Also found in my manual that the factory was 18". Oh and i have no handling issues I'm not trying to grind my pegs by no means either, that boils down to the rider more than the rim. :P :P ;D
Offline ekim98
« Reply #18 on: May 08, 2008, 09:51:59 AM »
I'm not sure how to measure my rim. It's 3-3/8" wide, but it doesn't fold in like the front rim, it's flanged that flairs out to aprox. 3-5/8" wide. It's appears to be a pretty thick metal and the bead edge is only single metal thickness. The tire itself measures 5.119" wide at the widest point. I could fit a 5-1/2" wide tire and not rub. I've already replaced the rear brake strap so I have the room. Bridgestone makes a Spitfire tire 150 wide but it's about 1" shorter than what I have now. Don't really want to drop the rear of the bike another 1/2".
Offline rbirkhan
« Reply #19 on: May 08, 2008, 10:02:49 AM »
5.10 thats huge is this a cb750? If so what was done to make it clear?
Offline rbirkhan
« Reply #20 on: May 08, 2008, 10:07:10 AM »
Forgot to refresh ignore my last post this is all good information thanks guys. Cant wait to see that fat rubber on the back.
Offline ekim98
« Reply #21 on: May 08, 2008, 10:09:06 AM »
Yes, it's a 78 750k. They have a wider stock swingarm. As it sits right now I have approx. 1/2" clearance between both the chain and the brake stay arm. All I did was replace the brake stay arm and space it out about 3/16" more with a couple of flat washers. The chain and sprocket are still in stock location.
« Reply #22 on: May 08, 2008, 08:04:27 PM »
They fit on any year CB 750 K.
« Reply #23 on: June 09, 2008, 08:26:03 PM »
Yup, way too heavy for performance sake.
Offline kghost
« Reply #24 on: June 09, 2008, 08:56:28 PM »
I have a 16 harley rim on a honda hub....
Not perfect but servicable.
Needs bearings.
I should warn ya its a heavy boat anchor of a wheel.
Stranger in a strange land
