Author Topic: spark plug problem  (Read 947 times)
Offline carl550k
  • 76 550k, 99 honda shadow aero
spark plug problem
« on: May 07, 2008, 11:30:54 AM »
hey all, went to have a look at the plugs today(76 550k). 1,2 and 4 all came out a little tight. after a cleaning and a dab of antisieze they went in smoothly. the problem is #3 , after the first few turns out things really tighten up. it gets to the point of i think its going to either break off or mess up the threads. i tried going back and forth a little at a time but only to a certain point. i finally tightnedup the plug to where its back in and seated an left it since the bike is running really good. any suggestions? thanks carl
Offline 750K2
  • new rider with an old bike
Re: spark plug problem
« Reply #1 on: May 07, 2008, 12:02:20 PM »
sounds like it was stripped when it was installed.  btw, i've never heard of applying anti-seize to plugs as the plug has to be grounded to the case and anti-seize would only get in the way. then again, i could be wrong about that.  one thing that you MIGHT try is to work the plug up to the sticking point and back down, then out again, repeatedly.  backing down gives the plug threads a chance to break the chip.  i've done this before but never on anything nearly as valuable as a case.  an other suggestion as to what to do about #3 though is to back it out and re-tap the threads.  the bad part is that would leave metal debris you'd have to remove from the cylinder.  you've got an issue on your hands my friend.
